im new in garuda linux i have 2 wifi adapters one is intigrated and another one is external that im using to connect to a wifi and the integrated one is free that i want to use to initiate hotspot and i have absolutely no idea how i should do that can anybody explain it how i should do that
iw dev
phy#3
Interface wlp6s0f4u2
ifindex 6
wdev 0x300000001
addr f0:a7:31:28:b9:ce
type managed
channel 1 (2412 MHz), width: 20 MHz, center1: 2412 MHz
txpower 20.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
phy#1
Interface wlp3s0
ifindex 3
wdev 0x100000001
addr 52:a2:bb:6c:21:90
type managed
txpower 3.00 dBm
multicast TXQ:
0 0 41 0 0 0 0 5398 46
wlp3s0 is the one i want to use for hotspot thank you ![:heavy_heart_exclamation: :heavy_heart_exclamation:](https://forum.garudalinux.org/images/emoji/google/heavy_heart_exclamation.png?v=12)
sudo garuda-inxi
Kernel: 6.6.16-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=82afb56e-dcc9-440c-8380-1967a2e102c2 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15
FA506IHRB_FA506IHRB v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506IHRB v: 1.0 serial: <filter>
UEFI: American Megatrends v: FA506IHRB.307 date: 12/28/2022
ID-1: BAT1 charge: 61.9 Wh (81.9%) condition: 75.6/90.2 Wh (83.8%)
volts: 15.6 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
Info: model: AMD Ryzen 5 4600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 838 high: 3097 min/max: 400/4006 base/boost: 3000/4000
scaling: driver: amd-pstate-epp governor: performance volts: 1.2 V
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 3097 5: 400 6: 400
7: 2970 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 71899
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 27.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 322e:202c
class-ID: 0e02
Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x004d built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.3.5-arch1.1
renoir LLVM 16.0.6 DRM 3.54 6.6.16-1-lts) device-ID: 1002:1636
memory: 500 MiB unified: no
API: Vulkan v: 1.3.276 layers: 10 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.3.5-arch1.1
device-ID: 1002:1636 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 545.29.06
device-ID: 10de:1f9d surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
API: ALSA v: k6.6.16-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-3: TP-Link TL-WN822N Version 4 RTL8192EU driver: rtl8xxxu type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:4 chip-ID: 2357:0108
IF: wlp6s0f4u2 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:3563
Local Storage: total: 942.7 GiB used: 346.56 GiB (36.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 31.9 C
SMART: yes health: PASSED on: 56d 4h cycles: 1,507
read-units: 26,371,701 [13.5 TB] written-units: 12,812,615 [6.56 TB]
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
fw-rev: FXM7201Q temp: 28.9 C scheme: GPT
SMART: yes health: PASSED on: 23d 3h cycles: 1,421
read-units: 19,162,320 [9.81 TB] written-units: 15,378,558 [7.87 TB]
ID-1: / raw-size: 73.3 GiB size: 73.3 GiB (100.00%) used: 51.36 GiB (70.1%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3
used: 27.6 MiB (10.8%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:5
ID-3: /home raw-size: 73.3 GiB size: 73.3 GiB (100.00%)
used: 51.36 GiB (70.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-4: /var/log raw-size: 73.3 GiB size: 73.3 GiB (100.00%)
maj-min: 259:3
ID-5: /var/tmp raw-size: 73.3 GiB size: 73.3 GiB (100.00%)
maj-min: 259:3
ID-1: swap-1 type: zram size: 15.05 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.6 C mobo: 34.0 C gpu: amdgpu temp: 27.0 C
Fan Speeds (rpm): cpu: 3200
Processes: 345 Uptime: 3h 37m wakeups: 2 Memory: total: 16 GiB note: est.
available: 15.05 GiB used: 4.08 GiB (27.1%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2106 libs: 581 tools: octopi,paru
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.31
Garuda (2.6.23-1):
System install date: 2023-12-03
Last full system update: 2024-02-08
Windows dual boot: Yes
There is the Garuda Network thing…with a hotspot option in it pointing to a [WIFI hotspot tool] , You could also try this:
nmcli d wifi hotspot ifname [e.g wlp3s0] ssid [my_wifi_name] password [my_password]
Well since you want the internal one, this will probably hit right at it
nmcli d wifi hotspot ssid [my_wifi_name] password [my_password]
You cud try that and see if its of help, of course you have to install [nmcli] if its missing.
