Recently updated packages with sudo pacman -Syu and after the update
im not able to install any other package, because the new timeshift depended on a new library file which i couldnt find .
timeshift: error while loading shared libraries: libicuuc.so.69: cannot open shared object file: No such file or directory
First of all, I'd try to check which package requires that file: pacman -Qo libicuuc.so.69
Then I'd try to reinstall that package, maybe it was a partial update...
It’s definitely a partial update somewhere along the line. icu was updated to 69 a while ago now, so if the timeshift package is still expecting icu=68 then either it’s from the AUR and needs to be rebuilt, or from an out-of-date ChaoticAUR mirror.
Hey,
Thanks for reaching out,
after running sudo pacman -Qo libicuuc.so.69
i got error: No package owns libicuuc.so.69
i tried rebuilding the timeshift package using pamac but to install something
timeshift starts running and runs into the above error stopping the installation :''(
is it possible to install without initiating timeshift.
I hv libicuuc.so.68 in my /usr/lib/
This is possible.
I think the way it works is that pacman has a hook to timeshift-autosnap.
This tool should have a config to disable the script to run.
So the easiest way IMO would be to temporarily disable there.
Thank you so much everyone : )
It got fixed
As you said it was a partial update, it stopped after giving a message that packages were invalid or corrupt (This was my mistake, sorry for not mentioning this before )
after updating the keyrings and following the above instructions it got solved
Thank you so much for helping out
