Trim with LUKS and BTRFS
Been using Garuda for a couple of months now, Cinnamon most recently. I originally setup the fstrim.timer to automatically trim weekly. But when I checked the logs, I noticed it only trimmed my EFI partition.
I manually ran sudo fstrim -av and it did the same thing, outputting just a single line for EFI and ignoring my LUKS/BTRFS volume/subvolumes.
I know my drive supports trim, as I always used it before. So I assume there is something I don't understand about interactions between LUKS, BTRFS and trim. But I tried Googling it and it seems it is supported and should work. So not really sure what's up.
Here is my fstab:
UUID=1217-F606                            /boot/efi      vfat    defaults,noatime 0 2
/dev/mapper/luks-33f83e27-a041-4247-8546-0ae6caf4106f /              btrfs   subvol=/@,defaults,noatime,compress=zstd 0 0
/dev/mapper/luks-33f83e27-a041-4247-8546-0ae6caf4106f /home          btrfs   subvol=/@home,defaults,noatime,compress=zstd 0 0
/dev/mapper/luks-33f83e27-a041-4247-8546-0ae6caf4106f /root          btrfs   subvol=/@root,defaults,noatime,compress=zstd 0 0
/dev/mapper/luks-33f83e27-a041-4247-8546-0ae6caf4106f /srv           btrfs   subvol=/@srv,defaults,noatime,compress=zstd 0 0
/dev/mapper/luks-33f83e27-a041-4247-8546-0ae6caf4106f /var/cache     btrfs   subvol=/@cache,defaults,noatime,compress=zstd 0 0
/dev/mapper/luks-33f83e27-a041-4247-8546-0ae6caf4106f /var/log       btrfs   subvol=/@log,defaults,noatime,compress=zstd 0 0
/dev/mapper/luks-33f83e27-a041-4247-8546-0ae6caf4106f /var/tmp       btrfs   subvol=/@tmp,defaults,noatime,compress=zstd 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
And system info:
  Kernel: 6.4.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=2cd206d5-5974-450c-b126-23cec2e9e234 rw rootflags=subvol=@
    quiet rd.luks.uuid=33f83e27-a041-4247-8546-0ae6caf4106f quiet
  Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
    v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: ROG Zephyrus S17 GX703HS_GX703HS
  Mobo: ASUSTeK model: GX703HS v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: GX703HS.311 date: 09/28/2021
  ID-1: BAT0 charge: 57.5 Wh (72.5%) condition: 79.3/90.0 Wh (88.1%)
    volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 90
  ID-2: hidpp_battery_0 charge: 96% condition: N/A volts: 4.1 min: N/A
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    microcode: 0x44
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1859 high: 3330 min/max: 800/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3094 2: 2300 3: 1259
    4: 2300 5: 1765 6: 3330 7: 1806 8: 2300 9: 2379 10: 800 11: 1193 12: 800
    13: 2311 14: 939 15: 2300 16: 872 bogomips: 73728
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: ASUSTeK driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: none off: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
    vendor: ASUSTeK driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm
    non-free: 535.xx+ status: current (as of 2023-07) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: DP-3
    empty: none bus-ID: 01:00.0 chip-ID: 10de:249c class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 13d3:5458
  Device-4: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8.1:19
    chip-ID: 046d:085b class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting,nvidia
    dri: iris gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
    s-diag: 777mm (30.58")
  Monitor-1: DP-3 mapped: DP-0 note: disabled pos: primary
    model: Dell S3222DGM serial: <filter> built: 2021 res: 2560x1440 dpi: 93
    gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 806mm (31.7") ratio: 16:9
    modes: max: 2560x1440 min: 640x480
  Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: AU Optronics 0xde95
    built: 2020 res: 2560x1440 dpi: 256 gamma: 1.2 size: 381x214mm (15x8.43")
    diag: 437mm (17.2") ratio: 16:9 modes: 3840x2160
  API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX 3080
    Laptop GPU/PCIe/SSE2 direct-render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
    chip-ID: 8086:43c8 class-ID: 0403
  Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
  Device-4: XMOS EDIFIER S3000 Pro driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8.3:16
    chip-ID: 20b1:30a0 class-ID: 0300
  Device-5: XMOS iFi (by AMR) HD USB Audio
    lanes: 1 mode: 2.0 bus-ID: 3-8.4:17 chip-ID: 20b1:3008 class-ID: 0300
  API: ALSA v: k6.4.3-zen1-2-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
    lanes: 1 port: 3000 bus-ID: 2e:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
    lanes: 1 bus-ID: 2f:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-14:11
    chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
    address: <filter>
  Local Storage: total: 1.84 TiB used: 415.6 GiB (22.0%)
    model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: GXA7301Q temp: 47.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 49.9 C
  ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
    used: 415.6 GiB (44.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-33f83e27-a041-4247-8546-0ae6caf4106f
    used: 724 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:7
  ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-4: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-5: /var/tmp raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.03 GiB used: 122 MiB (0.4%) priority: 100
  System Temperatures: cpu: 59.0 C mobo: N/A
  Processes: 406 Uptime: 13h 50m wakeups: 49 Memory: total: 32 GiB note: est.
  available: 31.03 GiB used: 15.32 GiB (49.4%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
  pm: pacman pkgs: 1518 libs: 479 tools: octopi,paru Shell: fish v: 3.6.1
  default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.28
  System install date:     2023-07-02
  Last full system update: 2023-07-17
Something from the archives. It address fstrim, SSDs, and BTRFS.
https://archive.kernel.org/oldwiki/btrfs.wiki.kernel.org/index.php/FAQ.html#Is_Btrfs_optimized_for_SSD.3F
I think you may be missing a couple steps described in the ArchWiki article here: dm-crypt/Specialties - ArchWiki
To enable TRIM support during boot, set the following kernel parameters.
rd.luks.options=discard
Note: The rd.luks.options=discard kernel option does not have any effect on devices included in the initramfs image’s /etc/crypttab file (/etc/crypttab.initramfs on real root). You must specify option discard in /etc/crypttab.initramfs.
Besides the kernel option, it is also required to periodically run fstrim or mount the filesystem (e.g. /dev/mapper/root in this example) with the discard option in /etc/fstab. For details, please refer to the TRIM page.
For LUKS devices unlocked via /etc/crypttab use option discard, e.g.:
/etc/crypttab
luks-123abcdef-etc UUID=123abcdef-etc none discard
After adding the rd.luks.options=discard kernel parameter in /etc/default/grub and adding the discard option for each device to /etc/crypttab, rebuild the initramfs:
sudo dracut-rebuild
And regenerate the Grub configuration file:
sudo update-grub
Ah perfect, that resolved it, thanks.
I misunderstood when I first read through and thought that the discard option was only if you wanted to enable automatic TRIM on file deletion. But I see it actually marks the device as supporting TRIM at all.
