Hello all. Installed Garuda (Xfce) yesterday (only five years late
I have two SSDs in my laptop
- 256GB where I have installed Garuda using LUKS encryption and the formatting defaults so it consists of a FAT32 /boot/efi and a Btrfs /
- 4TB already formatted as LUKS encrypted EXT4, mounted as /mnt/Data (mostly media files, but also an hourly rsync backup of most of /home)
The output of systemctl status btrfs-trim.timer is:
● btrfs-trim.timer - Discard unused blocks on a mounted filesystem
Loaded: loaded (/usr/lib/systemd/system/btrfs-trim.timer; enabled; preset: disabled)
Active: active (waiting) since Fri 2025-03-21 09:35:21 GMT; 1h 23min ago
Invocation: 9b6f13dcf454433ba361053fa73ba5fb
Trigger: Tue 2025-04-01 00:00:00 BST; 1 week 3 days left
Triggers: ● btrfs-trim.service
Docs: man:fstrim
and so I am assuming that btrfs-trim will run on the / Btrfs partition on the 1st of every month.
For the 4TB SSD, I have followed the instructions at dm-crypt/Specialties - ArchWiki and the output of sudo cryptsetup luksDump /dev/sda | grep Flags is allow-discards. I have also enabled fstrim-timer and the output of systemctl status fstrim.timer is
● fstrim.timer - Discard unused filesystem blocks once a week
Loaded: loaded (/usr/lib/systemd/system/fstrim.timer; enabled; preset: disabled)
Active: active (waiting) since Fri 2025-03-21 10:34:28 GMT; 25min ago
Invocation: da3f612bb4c84f09aa0e0879c9a69066
Trigger: Mon 2025-03-24 00:50:45 GMT; 2 days left
Triggers: ● fstrim.service
Docs: man:fstrim
so I am assuming that fstrim will run on the 4TB SSD weekly on a Monday.
I have two questions:
- Are my assumptions above correct that
btrfs-trimwill run on the 1st of the month only on the / btrfs partition, and thatfstrimwill run weekly on a Monday only on the 4TB SSD? - What happens when the 1st of the month is a Monday (September is the next one)? I notice a time offset between the two triggers above, but my laptop is highly unlikely to be on at these times. Would
btrfs-trimandfstrimboth run on booting my laptop on Mon 1st Sept, and would there be any conflicts between them?
I hope the above makes sense.
Kernel: 6.13.7-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f3aaf53c-eae0-4902-9e91-266d214a3fe7 rw rootflags=subvol=@
quiet rd.luks.uuid=61270517-44f2-4f88-8fe2-64c24eeb9c41 loglevel=3
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Laptop System: CLEVO product: W55xEU v: N/A
serial: <superuser required> Chassis: No Enclosure type: 10
Mobo: CLEVO model: W55xEU v: D02 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 4.6.5
date: 03/05/2013
ID-1: BAT0 charge: 54.7 Wh (100.0%) condition: 54.7/62.2 Wh (88.0%)
volts: 12.1 min: 11.1 model: NOTEBOOK BAT type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-3632QM bits: 64 type: MT MCP arch: Ivy Bridge
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1200 min/max: 1200/3200 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
7: 1200 8: 1200 bogomips: 35119
Device-1: Intel 3rd Gen Core processor Graphics vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: crocus gpu: i915
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99")
Monitor-1: LVDS-1 model: LG Display 0x037e built: 2011 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 141 gamma: 1.2
size: 345x194mm (13.58x7.64") diag: 396mm (15.6") ratio: 16:9
modes: 1920x1080
API: Vulkan v: 1.4.304 layers: 7 device: 0 type: integrated-gpu name: Intel
HD Graphics 4000 (IVB GT2) driver: N/A device-ID: 8086:0166
Info: Tools: api: vulkaninfo de: xfce4-display-settings
vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
API: ALSA v: k6.13.7-arch1-1 status: kernel-api tools: N/A
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:0887
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 03:00.2 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f2 state: down mac: <filter>
Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2
chip-ID: 8087:07da class-ID: e001
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 3.86 TiB used: 3.13 TiB (81.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT4000MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 temp: 28.0 C
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SMS200S3240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: BBF0 temp: 42.0 C scheme: GPT
used: 26.17 GiB (11.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-61270517-44f2-4f88-8fe2-64c24eeb9c41
used: 768 KiB (0.3%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 66.0 C mobo: N/A
Memory: total: 16 GiB available: 15.49 GiB used: 3.3 GiB (21.3%)
Processes: 293 Power: uptime: 2h 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1397 libs: 421 tools: pacseek,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.37
System install date: 2025-03-20
Last full system update: 2025-03-21 ↻
