Output of garuda-inxi at the end.
I set up edge scrolling on my touchpad (as oppossed to the default two-finger scrolling). Every so often the setting reverts back to the default. The strange thing is that when I go back to the setting I see the "Touchpad Edges" option is selected, but the machine behaves as if "Two fingers" were selected. I tried selecting "Two fingers" and clicking apply, then selecting "Touchpad Edges" and clicking apply, but nothing happens. I'm not sure what triggers the reversal; this time it happened after booting up my computer. And I'm not sure what "fixes" it and switches back to the actual selection ("Touchpad Edges"). I tried rebooting but that didn't fix it either. This is not the first time it has happened; in previous times the problem just "fixed" itself at some point but it's a recurring problem.
] × garuda-inxi
Kernel: 6.2.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c5880357-769f-4d8f-a77f-611b7a01dd58 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: Dell product: Latitude 6430U v: 01
serial: Chassis: type: 9 serial:
Mobo: Dell model: 0V4GYG v: A00 serial: BIOS: Dell
v: A03 date: 12/03/2012
ID-1: BAT0 charge: 3.3 Wh (9.4%) condition: 35.2/62.2 Wh (56.6%) volts: 10.5
min: 11.1 model: Samsung SDI DELL P70V52C type: Li-ion serial:
Device-1: wacom_battery_0 model: Wacom Intuos PT S 2 serial: N/A
charge: 100% status: full
Info: model: Intel Core i7-3667U bits: 64 type: MT MCP arch: Ivy Bridge
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1994 min/max: 800/3200 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1994 2: 1994 3: 1994 4: 1994 bogomips: 19936
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Sunplus Innovation Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.5:4 chip-ID: 1bcf:289b class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: BOE Display 0x05f6 built: 2013 res: 1366x768
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.2 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) direct-render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
API: ALSA v: k6.2.11-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
IF: eno1 state: down mac:
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:422b
IF: wlp2s0 state: up mac:
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 268.2 GiB used: 34.09 GiB (12.7%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SB32G size: 29.72 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: LITE-ON IT model: LMT-256M6M-41 mSATA
256GB SED size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: rev: 10F scheme: MBR
ID-1: / raw-size: 154.4 GiB size: 154.4 GiB (100.00%)
used: 34.09 GiB (22.1%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /home raw-size: 154.4 GiB size: 154.4 GiB (100.00%)
ID-3: /var/log raw-size: 154.4 GiB size: 154.4 GiB (100.00%)
ID-4: /var/tmp raw-size: 154.4 GiB size: 154.4 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 591.5 MiB (7.6%)
System Temperatures: cpu: 85.0 C mobo: 66.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 7021
Processes: 221 Uptime: 39m wakeups: 3 Memory: 7.63 GiB
used: 3.89 GiB (50.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: 1489 pm: pacman pkgs: 1483
libs: 383 tools: octopi,pamac,paru,yay pm: flatpak pkgs: 6 Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
error: GPGME error: No data
System install date: 2023-04-11
Last full system update: 2023-04-20
Windows dual boot:
