Touchpad gestures and brave
when i do three finger swipe up, it is taking me to next desktop, how to resolve that and in brave browser, i cant use two finger swipe left or right to go foreward or backward, i need some help please
  Kernel: 6.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=6e42085a-dc4c-4b30-9e89-8debb4d0ba3a rw rootflags=subvol=@
    quiet loglevel=3
  Desktop: GNOME v: 49.3 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Garuda base: Arch Linux
  Type: Laptop System: LENOVO product: 82NC v: YG Slim 7 Pro 14IHU5
    serial: <superuser required> Chassis: type: 10 v: YG Slim 7 Pro 14IHU5
  Mobo: LENOVO model: VIUU4 v: SDK0K17763 WIN serial: <superuser required>
    part-nu: LENOVO_MT_82NC_BU_idea_FM_ uuid: <superuser required>
    Firmware: UEFI vendor: LENOVO v: FJCN75WW date: 03/17/2023
  ID-1: BAT1 charge: 42.9 Wh (86%) condition: 49.9/61 Wh (81.8%) power: 7.3 W
    volts: 16.45 min: 15.44 model: Celxpert L19C4PH3 type: Li-poly
    serial: <filter> charging: status: discharging type: long_life
    avail: long_life,standard cycles: N/A
  Info: model: 11th Gen Intel Core i5-11320H bits: 64 type: MT MCP
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
    microcode: 0x3C
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 400 min/max: 400/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 50995
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
    built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5419
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model-id: CSO 0x140c built: 2021 res: 2880x1800 dpi: 242
    gamma: 1.2 size: 302x188mm (11.89x7.4") diag: 356mm (14") ratio: 16:10
    modes: 2880x1800
  Info: Tools: x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0401
  API: ALSA v: k6.18.6-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
  Local Storage: total: 476.94 GiB used: 7.43 GiB (1.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X084N
    lanes: 4 tech: SSD serial: <filter> fw-rev: 41010C22 temp: 38.9 C
    used: 7.43 GiB (1.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 15.4 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 42.0 C mobo: N/A
  Memory: total: 16 GiB note: est. available: 15.4 GiB used: 5.96 GiB (38.7%)
  Processes: 343 Power: uptime: 38m states: freeze,mem,disk suspend: s2idle
    suspend, test_resume image: 6.14 GiB services: gsd-power,
  Packages: pm: pacman pkgs: 1091 libs: 337 tools: paru Compilers:
    gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.3.3
    running-in: gnome-terminal inxi: 3.3.40
Garuda (2.12.3-2):
  System install date:     2026-01-27
  Garuda release:          260115
  Last full system update: 2026-01-27
25/26 checks run in 1.18 seconds ⌛
Powered by garuda-health 🦅
Have you checked Settings>Mouse & Touchpad>Touchpad to see if you can adjust settings?
Hi,
Normally one issue per Topic :wink:
Did you checked the Brave Settings?
Maybe this give you hints. im not on a laptop with Touchpad gestures.
Actually the settings for 3- and 4-finger gestures aren’t exposed in Gnome settings. You can use the “Touchpad Gesture Customization” extension to change their behavior.
