It’s a bit wierd issue but in GNOME either X11 or Wayland, when Desktop Zoom is turned ON, the touchpad click, scroll not working.
Is it with me only or others also? Please let me know if some new setting is there or how to enable clicks and scroll while using magnifier.
garuda-inxi :
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=18595224-2d53-4b38-812e-ff53fd49cf27 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 systemd.unified_cgroup_hierarchy=1
loglevel=3 nvidia_drm.modeset=1 ibt=off
Desktop: GNOME v: 46.0 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy avail: swaylock dm: 1: GDM v: 43.0 2: SDDM
note: stopped Distro: Garuda base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec2xxx v: N/A
Mobo: HP model: 88DE v: 96.34 serial: <superuser required>
part-nu: 471C3PA#ACJ uuid: <superuser required> UEFI: AMI v: F.26
date: 10/12/2023
ID-1: BAT0 charge: 38.4 Wh (89.1%) condition: 43.1/43.1 Wh (100.0%)
power: 17.8 W volts: 12.8 min: 11.6 model: HP Primary type: Li-ion
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000F
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2841 high: 3967 min/max: 400/4280 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3174 2: 3171 3: 3556
4: 400 5: 3961 6: 3967 7: 3965 8: 3966 9: 3967 10: 400 11: 3174 12: 400
bogomips: 79052
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0300
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 51.0 C
Device-3: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2
chip-ID: 30c9:0035 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia dri: radeonsi
s-diag: 583mm (22.95")
Monitor-1: eDP-1 mapped: eDP-1-0 model: AU Optronics 0x2992 built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia v: 550.76
device-ID: 10de:25a2 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8852
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0bda:2852
Local Storage: total: 476.94 GiB used: 97.46 GiB (20.4%)
model: MTFDHBA512TDV-1AZ1AABHA size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS0032 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 40.16 GiB (66.9%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 615 MiB size: 613.8 MiB (99.80%)
used: 19.3 MiB (3.2%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:9
ID-3: /home raw-size: 95.4 GiB size: 95.4 GiB (100.00%)
used: 57.28 GiB (60.0%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
used: 40.16 GiB (66.9%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: swap-2 type: zram size: 14.97 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 65.8 C mobo: N/A
Fan Speeds (rpm): fan-1: 0 fan-2: 0
GPU: device: nvidia screen: :0.0 temp: 52 C device: amdgpu temp: 52.0 C
Memory: total: 16 GiB note: est. available: 14.97 GiB used: 3.55 GiB (23.7%)
Processes: 376 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.95 GiB services: gsd-power,
Packages: pm: pacman pkgs: 1909 libs: 478 tools: gnome-software, octopi,
pamac, paru, yay pm: flatpak pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: kgx inxi: 3.3.34
System install date: 2024-04-21
Last full system update: 2024-04-21
Is partially upgraded: Yes
Failed units: clamav-freshclam.service
