Hello
I have some issues with gnome touche and gnome gestures.
If i use pinch zoom with brave, it first of all workand zoom, but it trigger the gnome menu every timme i pinch, it there anyway to avid it, i have tried with the x11gesture extention, but i have no effect.
Kernel: 6.10.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f62b95d8-c54f-42ba-ae16-446bf9a4eeec rw rootflags=subvol=@
Desktop: GNOME v: 46.4 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Garuda base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LI_FX506LI
Mobo: ASUSTeK model: FX506LI v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: FX506LI.310
date: 11/26/2021
ID-1: BAT1 charge: 31.7 Wh (96.1%) condition: 33.0/48.2 Wh (68.6%)
volts: 12.3 min: 11.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
8: 800 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 13d3:56a2
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.1.5-arch1.2
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 Ti driver: nvidia v: 555.58.02
device-ID: 10de:1f95 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.5-arch1.2 (LLVM
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
API: ALSA v: k6.10.4-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
Local Storage: total: 953.87 GiB used: 177.09 GiB (18.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1101 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11190001 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 476.54 GiB size: 476.54 GiB (100.00%)
used: 177.06 GiB (37.2%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 27 MiB (28.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 476.54 GiB size: 476.54 GiB (100.00%)
ID-4: /var/log raw-size: 476.54 GiB size: 476.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 476.54 GiB size: 476.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C pch: 51.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB available: 15.46 GiB used: 2.32 GiB (15.0%)
Processes: 317 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: gsd-power,
Packages: 1305 pm: pacman pkgs: 1296 libs: 432
tools: gnome-software,pamac,paru,yay pm: flatpak pkgs: 9 Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: alacritty inxi: 3.3.35
System install date: 2024-08-13
Last full system update: 2024-08-14
