Total war warhammer 3 says system does not support 3d api
I’m try out Garuda on a VirtualBox. I’m using the dr460nized version. I’ve tried out 2 games, marvel rivals and total war Warhammer 3. Marvel rivals doesn’t launch due to it being in a VirtualBox, so that I understand. But Warhammer 3 doesn’t work due to that issue.
I’ll break it down a bit.
First, When the launcher opens, it’s tells me that the linux distribution or version does not meet the game’s system requirements.
Then, it says that the CPU governor is not optimised for the game.
GPU or GPU drivers are not supported.
says that the game needs a Vulkan capable driver or Vulkan api.
then I hit play and that issue goes off and it doesn’t launch.
I tried looking this issue up and can’t find a solution.
anyone know what’s up?
here’s system details
haydo546@haydo546-virtualbox
○リᆰ OS Garuda Linux x86_64
¬ヤワ￯タモ Kernel Linux 6.17.4-zen2-1-zen
¬ヤワ￳ᄚマヨ Packages 1812 (pacman)[stable]
¬ヤヤ￯メノ Shell fish 4.1.2
￯メネ DE KDE Plasma 6.4.5
¬ヤワ￳ᄚᄃᄄ Window Manager KWin (Wayland)
¬ヤワ￳ᄚᄃᄄ Login Manager sddm 0.21.0 (Wayland)
¬ヤワ￳ᄚノᄐ WM Theme Sweet-Dark
¬ヤワ￳ᄚノᄐ Color Themes Dr460nized (Sweet) [Qt], Sweet-Dark [GTK2/3/4]
¬ヤワ￳ᄚタᄏ System Icons BeautyLine [Qt], BeautyLine [GTK2/3/4]
¬ヤワ○ワム System Fonts Fira Sans (10pt) [Qt], Fira Sans (10pt) [GTK2/3/4]
¬ヤヤ○゙ユ Terminal konsole 25.8.2
￳ᄚフᄁ PC Other
¬ヤワ￳ᄚᄏᅠ CPU AMD Ryzen 5 3600 (4) @ 3.60 GHz
¬ヤワ￳ᄚヘロ GPU VMware SVGA II Adapter
¬ヤワ￳ᄚヘロ Vulkan 1.4.328 [Software only]
¬ヤヤ￳ᄚヘᄍ Display(s) 1920x1080, 60 Hz
Kernel: 6.17.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: tsc avail: kvm-clock,acpi_pm
root=UUID=b80ef97e-9704-4643-812e-8c16d469cfba rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Virtualbox System: innotek GmbH product: VirtualBox v: 1.2
serial: <superuser required> Chassis: Oracle Corporation type: 1
Mobo: Oracle model: VirtualBox v: 1.2 serial: <superuser required>
uuid: <superuser required> UEFI: innotek GmbH v: VirtualBox date: 12/01/2006
Info: model: AMD Ryzen 5 3600 bits: 64 type: MCP arch: Zen 2 gen: 2
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported>
cache: 512 KiB note: check
Speed (MHz): avg: 3600 min/max: N/A cores: 1: 3600 2: 3600 3: 3600 4: 3600
bogomips: 28800
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.21.0.0 ports:
active: Virtual-1 empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5,
Virtual-6, Virtual-7, Virtual-8 bus-ID: 00:02.0 chip-ID: 15ad:0405
compositor: kwin_wayland driver: X: loaded: modesetting unloaded: fbdev
alternate: vesa,vmware dri: vmwgfx gpu: vmwgfx display-ID: 0
Monitor-1: Virtual-1 res: mode: 1920x1080 hz: 60 scale: 100% (1) size: N/A
modes: max: 1920x974 min: 640x480
API: EGL v: 1.5 platforms: device: 0 drv: vmwgfx device: 1 drv: swrast
gbm: drv: vmwgfx surfaceless: drv: vmwgfx wayland: drv: vmwgfx x11:
drv: vmwgfx
API: OpenGL v: 4.5 compat-v: 4.1 vendor: vmware mesa v: 25.2.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: SVGA3D; build: RELEASE; LLVM;
device-ID: 15ad:0405 memory: 1000 KiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 13 device: 0 type: cpu name: llvmpipe
(LLVM 21.1.3 256 bits) driver: mesa llvmpipe v: 25.2.5-arch1.1 (LLVM
21.1.3) device-ID: 10005:0000 surfaces: N/A
Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0
v: kernel bus-ID: 00:05.0 chip-ID: 8086:2415 class-ID: 0401
API: ALSA v: k6.17.4-zen2-1-zen status: kernel-api with: aoss
Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel port: c1a0
bus-ID: 00:03.0 chip-ID: 8086:100e class-ID: 0200
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge
driver: piix4_smbus v: N/A modules: i2c_piix4 port: N/A bus-ID: 00:07.0
chip-ID: 8086:7113 class-ID: 0680
Local Storage: total: 500 GiB used: 233.72 GiB (46.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: VirtualBox model: VBOX HARDDISK
size: 500 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 1.0 scheme: GPT
ID-1: / raw-size: 499.71 GiB size: 499.71 GiB (100.00%)
used: 233.72 GiB (46.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 656 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 499.71 GiB size: 499.71 GiB (100.00%)
ID-4: /var/log raw-size: 499.71 GiB size: 499.71 GiB (100.00%)
ID-5: /var/tmp raw-size: 499.71 GiB size: 499.71 GiB (100.00%)
ID-1: swap-1 type: zram size: 9.54 GiB used: 20 KiB (0.0%) priority: 100
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Memory: total: 9.88 GiB available: 9.55 GiB used: 3.6 GiB (37.7%)
Processes: 270 Power: uptime: 24m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: shutdown avail: reboot,suspend,test_resume
image: 3.79 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 258 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1812 libs: 525 tools: octopi,paru Compilers:
clang: 21.1.4 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.2
Garuda (2.11.1-1):
System install date:     2025-10-22
Garuda release:          251002
Last full system update: 2025-10-23
Relevant software:       snapper NetworkManager dracut garuda-hardware-profile-standard garuda-hardware-profile-vm
Failed units:            lm_sensors.service systemd-vconsole-setup.service
23/24 checks run in 1.87 seconds ¬フロ
Powered by garuda-health ￰゚ᆭナ
--- LOW ---
- Failed systemd services found: lm_sensors.service, systemd-vconsole-setup.service
Garuda as such is not supported in VM environments. You will have a lot of problems.
If you test Garuda in a VM its okay to see how it looks ~ how it feels. But to try anything serious on it as gaming usually will not work.
A virtual graphics adapter is not suitable for this - you would need at least GPU passthrough for this. But as @Seimus already mentioned:
