Total noob needing help with Netgear Wireless USB A6100
Hello. I explained my situation a bit in previous post but now I have the information needed. (Sorry if I should not create a new post) I am having difficulty getting my NetGear A6100 wireless usb adapter working with Linux.. I just switched to Garuda Linux last night so very noob to Linux.. VERY. Here is the output of inxi -Fxxxa Any help is MUCH appreciated and please speak to me as if I'm a child as I'm totally noob to all things Linux. Thank you all SO much!!
  Kernel: 5.10.4-107-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: intel_pstate=passive
  BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq
  root=UUID=11171806-a474-47f8-a9c3-5880c3dba1da rw rootflags=subvol=@
  Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Garuda Linux
  Type: Desktop Mobo: Intel model: S3000AHLX v: D40858-208
  serial: <filter> BIOS: Intel v: S3000.86B.02.00.0054.061120091710
  date: 06/11/2009
  Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter>
  charge: 70% (should be ignored) rechargeable: yes status: Discharging
  Info: Dual Core model: Intel Core2 6700 bits: 64 type: MCP
  arch: Core Merom family: 6 model-id: F (15) stepping: 6 microcode: D0
  L2 cache: 4 MiB
  flags: lm nx pae sse sse2 sse3 ssse3 vmx bogomips: 10676
  Speed: 2667 MHz min/max: 1596/2660 MHz Core speeds (MHz): 1: 2667
  2: 2667
  Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
  SMT disabled
  mitigation: Full generic retpoline, STIBP: disabled, RSB filling
  Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nvidia
  v: 460.27.04 alternate: nouveau,nvidia_drm bus ID: 03:00.0
  chip ID: 10de:13c2
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 650x366mm (25.6x14.4")
  s-diag: 746mm (29.4")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60
  OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 460.27.04
  direct render: Yes
  Device-1: NVIDIA GM204 High Definition Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 10de:0fbb
  Sound Server: ALSA v: k5.10.4-107-tkg-bmq
  Device-1: Intel 82573E Gigabit Ethernet driver: e1000e v: kernel
  port: 2000 bus ID: 04:00.0 chip ID: 8086:108c
  IF: enp4s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel 82541GI Gigabit Ethernet driver: e1000 v: kernel
  port: 1100 bus ID: 05:05.0 chip ID: 8086:1076
  IF: enp5s5 state: down mac: <filter>
  Local Storage: total: 931.52 GiB used: 14.88 GiB (1.6%)
  model: WDS100T2G0A-00JH30 size: 931.52 GiB block size: physical: 512 B
  logical: 512 B speed: <unknown> serial: <filter> rev: 0000
  ID-1: / raw size: 931.51 GiB size: 931.51 GiB (100.00%)
  used: 14.88 GiB (1.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw size: 931.51 GiB size: 931.51 GiB (100.00%)
  ID-3: /var/log raw size: 931.51 GiB size: 931.51 GiB (100.00%)
  ID-4: /var/tmp raw size: 931.51 GiB size: 931.51 GiB (100.00%)
  ID-1: swap-1 type: zram size: 3.39 GiB used: 0 KiB (0.0%)
  priority: 32767 dev: /dev/zram0
  ID-2: swap-2 type: zram size: 3.39 GiB used: 0 KiB (0.0%)
  priority: 32767 dev: /dev/zram1
  System Temperatures: cpu: 79.0 C mobo: N/A gpu: nvidia temp: 35 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 43%
  Processes: 195 Uptime: 27m wakeups: 2 Memory: 6.78 GiB
  used: 3.27 GiB (48.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  Packages: pacman: 1563 lib: 483 Shell: fish v: 3.1.2 running in: konsole
  inxi: 3.2.01
A post was merged into an existing topic: Getting NetGear A6100 to work with Garuda Linux
