I will just start by posting this…
╭─fenris@fenris in ~ took 11ms
╰─λ garuda-inxi
Kernel: 6.1.70-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=576a4f6d-5c57-475b-8279-4f23d821f833 rw rootflags=subvol=@
quiet resume=UUID=6feff68d-462f-4c25-aead-653957ef83a3 loglevel=3 ibt=off
Type: Desktop Mobo: AZW model: MINI S v: 10 serial: <superuser required>
UEFI: American Megatrends LLC. v: ADLNV104 date: 02/06/2023
Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x12
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 700 min/max: 700/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 6452
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: HDMI-A-2
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46d1 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: Acer G247HYL serial: <filter>
built: 2016 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
API: Vulkan v: 1.3.274 layers: 5 device: 0 type: integrated-gpu
name: Intel Graphics (ADL-N) driver: mesa intel v: 23.3.2-arch1.2
device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM
Device-1: Intel driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:54c8
Device-2: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 1-4.2:6 chip-ID: 0d8c:0102 class-ID: 0300
API: ALSA v: k6.1.70-1-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel CNVi: Wi-Fi driver: N/A modules: iwlwifi bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.1:3
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u4u1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
Local Storage: total: 1.38 TiB used: 541.88 GiB (38.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 476.94 GiB
tech: SSD serial: <filter> fw-rev: EHFM90.1 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 16.54 GiB (16.5%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 584 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 719 GiB size: 719 GiB (100.00%)
used: 97.53 GiB (13.6%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 16.54 GiB (16.5%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.4 GiB used: 122.5 MiB (0.8%)
ID-2: swap-2 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 278 Uptime: 19h 57m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.4 GiB used: 6 GiB (39.0%) Init: systemd v: 255
pm: pacman pkgs: 1459 libs: 434 tools: pamac,paru,yay Shell: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-12-28
Last full system update: 2024-01-05 ↻
Failed units: vmware-workstation-server.service vmware.service
So here is the scoop, a few weeks ago, I’m doing a new Garuda build on a Beelink MiniS Pro 12 computer. All is good for the most part short a few other little bugs I might post in some other forum topics, and I install the famous Tor browser.
I installed the Tor browser by doing sudo pacman -Syu torbrowser-launcher and it installed perfectly. Once installed, I load up the browser, it connects just fine, and can easily go visit sites governments around the world don’t want me to visit as every square inch of my life gets micro managed.
However a few days pass by, a few more things get installed as I customise my operating system, I go to click on the Tor browser icon to load up the browser just to find out it won’t load up anymore. I have reset my system a few times then try to click the icon again, it won’t load up. Not even Tor browser launcher setup icon works. I can’t figure out why this browser wont load up anymore. There are no error messages or anything, it just simply won’t load up. Any ideas?
I don’t know if this issue is related but the “Garuda Settings Manager” also won’t load up anymore either just like the Tor browser doesn’t load. So trying to access driver updates to get my wifi working doesn’t also seem accessible. But, like I said before, I don’t know if this is related since these applications issues seem to behave the same way for some reason.
