hi all,
I installed Garuda Wayfire but my top menu bar is missing. Looked up some fixes but none of them are working. Any help is appreciated. Thank you
hi all,
Hi there, welcome.
I moved the thread to the Wayfire category, the inxi one should be used only when you want to leave your inxi -Faz
there and reference it when needed in the topics.
Anyway, your inxi -Faz
was actually missing here...
Check if this helps:
Another thing to try:
Open the terminal and type killall wf-panel && wf-panel &
