Kernel: 6.9.1-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=b6b1f50f-bccb-4d49-b492-620cfc47af89 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop System: ASRock product: Z790 LiveMixer v: N/A
Mobo: ASRock model: Z790 LiveMixer serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 13.02
date: 12/29/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
Info: model: 13th Gen Intel Core i9-13900KF bits: 64 type: MST AMCP
microcode: 0x123
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 880 high: 1755 min/max: 800/5800:4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 989 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 1496 13: 1755
14: 1528 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800
23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800
32: 800 bogomips: 191692
Device-1: NVIDIA AD103 [GeForce RTX 4080] vendor: Gigabyte driver: N/A
alternate: nouveau non-free: 550.xx+ status: current (as of 2024-04)
arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2704
alternate: fbdev,nouveau,nv,vesa gpu: N/A display-ID: 0
Monitor-1: Unknown-1 res: 3840x2160 size: N/A modes: N/A
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast wayland: drv: swrast x11: drv: swrast
API: OpenGL v: 4.5 vendor: mesa v: 24.0.7-arch1.3 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 17.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 45.77 GiB unified: yes
display-ID: :1.0
Device-1: Intel Raptor Lake High Definition Audio vendor: ASRock
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb
API: ALSA v: k6.9.1-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Local Storage: total: 18.67 TiB used: 17.21 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Seagate model: BarraCuda Q5
ZP2000CV30001 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU5SH017
temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: TeamGroup
model: T-FORCE TM8FPZ004T size: 3.64 TiB block-size: physical: 512 B
fw-rev: EIFM51.3 temp: 36.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC38 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST12000NM0127
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: G006 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
size: 28.67 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 vendor: Toshiba model: MQ03UBB200
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400 serial: <filter>
fw-rev: 5438 scheme: MBR
ID-1: / raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
used: 17.21 GiB (3.4%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:5
used: 648 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:6
ID-3: /home raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
ID-4: /var/log raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
ID-5: /var/tmp raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.87 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 11.0 C mobo: 38.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1025 fan-3: 3169 fan-4: 0 fan-5: 925
fan-6: 0 fan-7: 0
Memory
Very frustrated. i had two gaming editions running, one from last years November installation, and one from April this year.
Both crashed after updating and will no longer boot. And now my new installation, with the latest Garuda Gaming edition, also crashed after updating after the first boot up. Which went fine.
As the update was progressing it flashed a error message about the nvidia drivers not being installed rightly into the kernel, after which it promptly crashed my computer. and only restoring a snap shot could get Garuda up and running again.
What could be the matter?
