i just wanted to say that i do not have this issue. ever since the replacement of latte-dock i can still drag and drop any window from the title bar when maximized or not.
i find this fact quite curious.
my garuda-itchy if it may help:
❯ garuda-inxi
Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=63f3c83e-5747-44de-974f-c89d4101bd95 rw rootflags=subvol=@
resume=UUID=c0d4fb48-27bb-458a-9d32-db4bea9d7420 loglevel=3 ibt=off
Type: Desktop Mobo: MSI model: Z77A-GD55 (MS-7751) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.11
date: 11/20/2013
Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3556 high: 3900 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3900 2: 3900 3: 3438
4: 3900 5: 3900 6: 3900 7: 1613 8: 3900 bogomips: 56001
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
chip-ID: 1002:731f class-ID: 0300
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Asus VX238 serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon RX 5600 XT (navi10
LLVM 15.0.7 DRM 3.52 6.4.10-zen2-1-zen) direct-render: Yes
vendor: Micro-Star MSI 7 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api with: aoss
Device-1: Intel 82579V Gigabit Network vendor: Micro-Star MSI driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 2.91 TiB used: 352.25 GiB (11.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SH103S3120G
tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SH103S3120G
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0107 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Kingston model: SA400S37480G
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD20EZRX-00D8PB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: MBR
ID-1: / raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
used: 14.75 GiB (37.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 71.04 GiB size: 71.04 GiB (100.00%)
used: 16.83 GiB (23.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
ID-5: /var/tmp raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 23.42 GiB used: 6.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 512 MiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
mem: 38.0 C
Processes: 307 Uptime: 3h 57m wakeups: 0 Memory: total: 24 GiB
available: 23.42 GiB used: 4.75 GiB (20.3%) Init: systemd v: 254
pm: pacman pkgs: 2011 libs: 560 tools: octopi,paru Shell: fish v: 3.6.1
running-in: konsole inxi: 3.3.29
System install date: 2023-04-12
Last full system update: 2023-08-18
my appearance settings:
global theme - sweetified plasma
app style - breeze
plasma style - sweet
colors - sweetified
window decorations - sweet-dark
icons - beautyline
cursors - sweet-cursors
i recall that when latte-dock was glitching out and just as the new dragonized theme was being constructed i set my machine up with the above settings and used a method of importing the old latte-dock dragonized theme style to the main top and quicklaunch bars via a context menu from the desktop environment directly.
i have not switched my theme since, other than to change my desktop background and the animated splash screen.
feel free to ask for any other info people may want/need to figure out exactly why so as to perhaps replicate it for other users.
desktop screenshot:
