I´m trying to get my nvidia data to appear in my modest first try at Conky.
Sacrificing goats and other witchcraft has had very little to no effect.
I´v found several methods to extract the data needed:
- Calling nvidia-smi directly. But that actually seems to impede performance.
- Calling nvidia-smi to store data in a file. But that involves scripts, which is beyond my competence.
- Using the built-in function ${nvidia temp}. This is, to me, the preferred solution. BUT I get the very annoying: “conky: print_nvidia_value: NV-CONTROL X extension not present”
nvidia-settings is installed, Conky is compiled with nvidia features.
I haven´t found the answer to this specific question on the forum. Is this a Wayland issue? Explain to me like I´m a toddler.
All help is appreciated.
Kernel: 6.15.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=e52d1137-1629-472c-ae1b-49f397ecfa81 rw rootflags=subvol=@
nvidia-drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 6.4.2 tk: Qt v: N/A info: frameworks v: 6.15.0
Mobo: ASUSTeK model: PRIME H610M-R D4 v: Rev 1.xx
UEFI-[Legacy]: American Megatrends v: 2801 date: 09/09/2023
Info: model: 12th Gen Intel Core i3-12100F bits: 64 type: MT MCP
microcode: 0x3A
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3457 min/max: 800/5500 scaling: driver: intel_pstate
governor: powersave cores: 1: 3457 2: 3457 3: 3457 4: 3457 5: 3457 6: 3457
7: 3457 8: 3457 bogomips: 52838
Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: Gigabyte driver: nvidia
v: 575.64.03 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none off: DP-1 empty: DP-2,HDMI-A-1,HDMI-A-2
bus-ID: 01:00.0 chip-ID: 10de:2882 class-ID: 0300
Monitor-1: DP-1 model: Samsung LC34G55T serial: <filter> built: 2022 res:
mode: 3440x1440 hz: 100 scale: 114% (1.15) to: 2991x1252 dpi: 109 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 3440x1440
min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
API: Vulkan v: 1.4.313 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4060 driver: nvidia v: 575.64.03
device-ID: 10de:2882 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.7 256 bits) driver: mesa llvmpipe v: 25.1.5-arch1.1 (LLVM
20.1.7) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: corectrl, lact, nvidia-settings,
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA AD107 High Definition Audio vendor: Gigabyte
API: ALSA v: k6.15.5-zen1-1-zen status: kernel-api with: aoss
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:0029
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 465.76 GiB used: 216.45 GiB (46.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV3S500G
lanes: 4 tech: SSD serial: <filter> fw-rev: SDS00101 temp: 40.9 C
scheme: MBR
ID-1: / raw-size: 448.79 GiB size: 448.79 GiB (100.00%)
used: 216.45 GiB (48.2%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 448.79 GiB size: 448.79 GiB (100.00%)
ID-3: /var/log raw-size: 448.79 GiB size: 448.79 GiB (100.00%)
ID-4: /var/tmp raw-size: 448.79 GiB size: 448.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.97 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 41.0 C mobo: 40.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 940 fan-4: 0 fan-6: 0 fan-7: 0
Memory: total: 16 GiB available: 15.42 GiB used: 3.57 GiB (23.1%)
Processes: 359 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
Packages: 1862 pm: pacman pkgs: 1856 libs: 563 tools: octopi,paru
pm: flatpak pkgs: 6 Compilers: clang: 20.1.7 gcc: 15.1.1 Shell: garuda-inxi
default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
Garuda (2.7.3-1):
System install date: 2025-07-05
Last full system update: 2025-07-07
