Hello Everyone.
I need assistance finding a driver or configuring it for tigerlake communication controller.
as shown in the link:
https://linux-hardware.org/?probe=ca0fbaa451
Can anyone point me in the direction i need to go? Much appreciated.
Thanks in advance.
Kernel: 5.15.61-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=56b6d61d-6361-4ad3-a60e-43737d514e39 rw rootflags=subvol=@
Desktop: Cinnamon v: 5.4.9 tk: GTK v: 3.24.34 wm: Mutter vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Micro-Star product: Sword 15 A11UD v: REV:1.0
Mobo: Micro-Star model: MS-1582 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E1582IMS.312 date: 04/08/2022
ID-1: BAT1 charge: 47.6 Wh (90.5%) condition: 52.6/52.0 Wh (101.2%)
volts: 12.6 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8D (141) stepping: 1 microcode: 0x40
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2113 high: 3861 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 2377 2: 2016 3: 1672
4: 3001 5: 3861 6: 1556 7: 2394 8: 1632 9: 1665 10: 2087 11: 1386
12: 1980 13: 2883 14: 1533 15: 2157 16: 1614 bogomips: 73728
prctl and seccomp
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 515.65.01 alternate: nouveau
non-free: 515.xx+ status: current (as of 2022-07) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a0 class-ID: 0302
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 3-10:4
chip-ID: 5986:211b class-ID: 0e02
Device-4: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-8.2:5 chip-ID: 046d:082d
Display: x11 server: X.Org v: 21.1.4 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: LG (GoldStar)
FULL HD serial: <filter> built: 2019 res: 1920x1080 hz: 75 dpi: 102
gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
Monitor-2: eDP-1 pos: right model: ChiMei InnoLux 0x1521 built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 3-8.2:5
bus-ID: 00:1f.3 chip-ID: 046d:082d class-ID: 0102 chip-ID: 8086:43c8
serial: <filter> class-ID: 0401
Device-2: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.15.61-1-lts running: yes
bus-ID: 3-14:6 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 2.76 TiB used: 390.21 GiB (13.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS1000G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S8I40100
temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: Expansion Desk size: 1.82 TiB block-size: physical: 4096 B
logical: 4096 B type: N/A serial: <filter> rev: 0737 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: SD MMC
size: 29.72 GiB block-size: physical: 512 B logical: 512 B type: SSD
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 25.42 GiB
(2.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 25.42
GiB (2.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 25.42
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 25.42
ID-1: swap-1 type: zram size: 31.04 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 413 Uptime: 8h 20m wakeups: 1 Memory: 31.05 GiB used: 4.08 GiB
(13.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: pacman: 1504 lib: 444 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-17
Last full system update: 2022-08-19 ↻
