i
Kernel: 6.8.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=a613e82f-ac23-44cf-bcab-a64bc638556e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
wm: kwin_wayland tools: xscreensaver,xscreensaver-systemd avail: xautolock
vt: 8 dm: 1: LightDM v: 1.32.0 2: SDDM note: stopped Distro: Garuda
Type: Desktop System: Micro-Star product: MS-7C56 v: 2.0
Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
Megatrends LLC. v: A.E0 date: 07/03/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540e
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3681 high: 3785 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3591 2: 3700
3: 3685 4: 3700 5: 3700 6: 3785 7: 3593 8: 3700 9: 3700 10: 3700 11: 3622
12: 3700 bogomips: 88800
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1, Writeback-1
bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
navi22 LLVM 17.0.6 DRM 3.57 6.8.5-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu
name: AMD Radeon RX 6700 XT driver: amd v: 2024.Q1.3 (LLPC)
device-ID: 1002:73df surfaces: xcb,xlib,wayland
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.5-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 85.68 TiB used: 45.76 TiB (53.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 1.86 TiB block-size: physical: 512 B
fw-rev: VC2S038E temp: 39.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWE150 size: 4.55 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: FP2A scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: KLEVV model: NEO N610 SSD 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 7D scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST8000DM004-2U9188
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Kingston model: SA400M8120G
tech: SSD serial: <filter> fw-rev: 61E1 scheme: MBR
ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: Backup+ Hub BK
size: 9.1 TiB block-size: physical: 4096 B logical: 512 B type: USB rev: 3.1
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: D781
ID-7: /dev/sdf maj-min: 8:80 vendor: Toshiba model: HDWN180 size: 7.28 TiB
block-size: physical: 4096 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: HDD rpm: 7200 serial: <filter> fw-rev: 0102
scheme: PMBR
ID-8: /dev/sdg maj-min: 8:96 vendor: Seagate model: Backup+ Hub BK
fw-rev: D781 scheme: GPT
ID-9: /dev/sdh maj-min: 8:112 vendor: Utania model: OOS12000G
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> scheme: GPT
ID-10: /dev/sdi maj-min: 8:128 vendor: Seagate model: Backup+ Hub BK
ID-11: /dev/sdj maj-min: 8:144 vendor: Seagate model: Backup+ Hub BK
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: D785 scheme: GPT
ID-12: /dev/sdk maj-min: 8:160 vendor: Hitachi model: HUH721010ALE601
size: 9.1 TiB block-size: physical: 4096 B logical: 4096 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> fw-rev: 0209 scheme: GPT
ID-13: /dev/sdl maj-min: 8:176 vendor: Western Digital
model: WD50NMZW-59BCBS0 size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 4800 serial: <filter> fw-rev: 4004 scheme: GPT
ID-14: /dev/sdm maj-min: 8:192 vendor: Western Digital
model: WD50NDZW-11A8JS0 size: 4.55 TiB block-size: physical: 4096 B
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1034 scheme: GPT
ID-1: / raw-size: 76.4 GiB size: 76.4 GiB (100.00%) used: 53.29 GiB (69.7%)
fs: btrfs dev: /dev/sdd2 maj-min: 8:50
ID-2: /boot/efi raw-size: 300.4 MiB size: 299.8 MiB (99.80%)
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdd1 maj-min: 8:49
ID-3: /home raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
used: 1.89 TiB (26.0%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-4: /var/log raw-size: 76.4 GiB size: 76.4 GiB (100.00%)
used: 53.29 GiB (69.7%) fs: btrfs dev: /dev/sdd2 maj-min: 8:50
ID-5: /var/tmp raw-size: 76.4 GiB size: 76.4 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.72 GiB used: 2.37 GiB (3.8%)
System Temperatures: cpu: 52.1 C mobo: N/A gpu: amdgpu temp: 53.0 C
mem: 50.0 C
Memory: total: 64 GiB note: est. available: 62.72 GiB used: 6.35 GiB (10.1%)
Processes: 469 Power: uptime: 19h 58m states: freeze,mem,disk
reboot, suspend, test_resume image: 25.07 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Packages: 2360 pm: pacman pkgs: 2355 libs: 587 tools: octopi,paru,yay
pm: flatpak pkgs: 5 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.25-1):
System install date: 2023-09-08
Last full system update: 2024-04-13 ↻
I wanted to try Wayland, after years and years of using Xorg and MATE, so I installed KDE. I basically like it, but…
Widgets are lacking, which may be because of the new KDE6 version, but I had temperature readings in MATE and not KDE. I tried installing a temperature widget, it told me it was already installed, and I can’t find it.
Krename is nowhere near as useful as MATE’s caja-rename.
Those are the main gripes. I like the dr460inized theme, once I found the menu. It’s certainly a polished desktop.
