Has anyone installed Garuda linux on the Thinkpad X1 Extreme?
If so does everything work?
Thank you
Thank you
It doesn't look like there are any real issues. At a glance it seems like the only thing you'll maybe have any issues with are the fingerprint reader, as it requires an experimental driver for now.
https://wiki.archlinux.org/title/Lenovo_ThinkPad_X1_Extreme
Is the battery life good? Any heating issues?
The battery life is as good as you decide to make it. There are plenty of ways to tune CPU/GPU frequencies. You should probably wait a short while for the newest Garuda ISOs, they're being built right now.
Ok, thanks for the info. Much appreciated
