ACPI Errors and Fan State Failure on Boot
Hi everyone,
I’m encountering several ACPI errors and a fan state failure on boot, and I’m hoping someone can help me troubleshoot these issues. Here’s a summary of what I’m seeing in my dmesg
output:
The fan runs normally, but i dont think temps are normal.On load average 1.0 it touches temps above 90 °C.
The laptop is a NON-OEM/ODM laptop.
Nokia PureBook S14 NKi511TL165S
Kernel Errors and Warnings:
╭─madmiz@madmiz in ~ as 🧙 took 7ms
╰─λ sudo dmesg | grep -i "error\|warn\|fail"
[ 0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ 0.223497] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR03._PLD], AE_NOT_FOUND (20240322/psargs-330)
[ 0.223502] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 0.223505] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS06._PLD due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 0.223537] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR04._PLD], AE_NOT_FOUND (20240322/psargs-330)
[ 0.223540] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 0.223543] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS07._PLD due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 0.498859] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.HEC.CFSP], AE_NOT_FOUND (20240322/psargs-330)
[ 0.498863] ACPI Error: Aborting method \_SB.PC00.LPCB.H_EC.TFN1._FST due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 0.498867] acpi INTC1044:00: Get fan state failed
[ 0.568033] RAS: Correctable Errors collector initialized.
[ 0.903104] ata2.00: failed to enable DIPM, Emask 0x40
[ 8.808819] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR03._PLD], AE_NOT_FOUND (20240322/psargs-330)
[ 8.808826] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.808832] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS06._PLD due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.808861] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR03._UPC], AE_NOT_FOUND (20240322/psargs-330)
[ 8.808865] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.808870] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS06._UPC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.808904] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR03._PLD], AE_NOT_FOUND (20240322/psargs-330)
[ 8.808908] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.808912] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS06._PLD due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.808948] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR04._PLD], AE_NOT_FOUND (20240322/psargs-330)
[ 8.808952] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.808956] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS07._PLD due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.808988] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR04._UPC], AE_NOT_FOUND (20240322/psargs-330)
[ 8.808993] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.808997] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS07._UPC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.809033] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR04._PLD], AE_NOT_FOUND (20240322/psargs-330)
[ 8.809038] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 8.809042] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS07._PLD due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 9.482892] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR04._PLD], AE_NOT_FOUND (20240322/psargs-330)
[ 9.482898] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 9.482902] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS07._PLD due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 9.495513] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.CR04._PLD], AE_NOT_FOUND (20240322/psargs-330)
[ 9.495519] ACPI Error: Aborting method \_SB.UBTC.RUCC due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 9.495523] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS07._PLD due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 13.228549] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.H_EC.CHRG.PPSS.FCHG], AE_NOT_FOUND (20240322/psargs-330)
[ 13.228560] ACPI Error: Aborting method \_SB.PC00.LPCB.H_EC.CHRG.PPSS due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[ 13.229493] intel-hid INTC1051:00: failed to enable HID power button
[ 14.313429] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 14.572641] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 14.839308] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 15.105957] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 15.372637] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 15.639400] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 15.906099] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 16.172637] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 720.137220] warning: `ThreadPoolForeg' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
╭─madmiz@madmiz in ~ as 🧙 took 30ms
[[]|[🔴]] => 🔴ERROR × garuda-inxi
Kernel: 6.10.0-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=c1d255ec-1e14-46d6-a671-75ab7a11fb19 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: Flipkart India Pvt. product: NKi511TL165S v: N/A
Mobo: Flipkart India Pvt. model: EM_TG618_96B_V1.1
serial: <superuser required> part-nu: Nokia PureBook S14
uuid: <superuser required> UEFI: American Megatrends LLC.
v: TGL_TG618_N_V4.1.17 date: 10/29/2021
ID-1: BAT0 charge: 45.0 Wh (100.0%) condition: 45.0/45.0 Wh (100.0%)
volts: 11.6 min: N/A model: Intel SR 1 SR Real Battery type: Unknown
serial: <filter> status: full
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 971 high: 1166 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1107 2: 944 3: 1076
4: 818 5: 586 6: 1030 7: 1044 8: 1166 bogomips: 38720
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: nCipher Security
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
compositor: kwin_wayland driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: 0
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.5 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 24.1.4-arch1.2
device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Emdoor Digital
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.10.0-1-mainline status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0a2a
Local Storage: total: 651.02 GiB used: 416.74 GiB (64.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Netac model: SSD 512GB
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: USB 3.2Gen1
size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Generic model: SD MMC MS PRO
size: 59.48 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
ID-1: / raw-size: 278.32 GiB size: 278.32 GiB (100.00%)
used: 215.34 GiB (77.4%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 81.3 MiB (84.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 278.32 GiB size: 278.32 GiB (100.00%)
ID-4: /var/log raw-size: 278.32 GiB size: 278.32 GiB (100.00%)
ID-5: /var/tmp raw-size: 278.32 GiB size: 278.32 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.36 GiB used: 656.2 MiB (4.2%)
System Temperatures: cpu: 56.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.36 GiB used: 3.76 GiB (24.4%)
Processes: 255 Power: uptime: 2h 27m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1569 libs: 475 tools: octopi,paru,yay
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-07-18
Last full system update: 2024-07-27 ↻
╭─madmiz@madmiz in ~ took 2s
╰─λ
sensors
╰─λ sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +56.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +52.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +55.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +54.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +57.0°C (high = +100.0°C, crit = +100.0°C)
BAT0-acpi-0
Adapter: ACPI interface
in0: 11.55 V
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +65.0°C
acpitz-acpi-0
temp1: +0.0°C
╭─madmiz@madmiz in ~ took 11ms
╰─λ
