I am using Garuda Linux KDE Dr460nized and when I run CS:GO or TF2 the system log me out and to point out I disabled ballo because my computer was too slow, Here's my device specifications
anasy@anas-pc
OS: Garuda Linux
Kernel: 5.15.2-zen1-1-zen
Uptime: 6 mins
Packages: 1801 (pacman), 12 (flatpak)
Shell: bash
DE: Plasma 5.23.3
WM: KWin
WM Theme: Sweet-Dark
Terminal: konsole
CPU: Intel i5-4670S (4) @ 3.8GHz
GPU: Intel HD Graphics
sorry for my bad english and my bad choice of words.
System: Kernel: 5.15.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d8bfc3dd-b8bb-4f2a-a53e-936586dab839
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: Hewlett-Packard product: N/A v: N/A serial: <filter> Chassis: type: 3
Mobo: Hewlett-Packard model: 18E6 serial: <filter> UEFI: Hewlett-Packard v: L01 v02.65
date: 07/13/2015
CPU: Info: Quad Core model: Intel Core i5-4670S bits: 64 type: MCP arch: Haswell family: 6
model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24744
Speed: 3014 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3014 2: 3093 3: 3093 4: 3093
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
Device-2: Chicony HP 2.0MP High Definition Webcam type: USB driver: uvcvideo bus-ID: 3-12:6
chip-ID: 04f2:b500 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2") s-diag: 581mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 96 size: 510x287mm (20.1x11.3") diag: 585mm (23")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 21.2.5 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-zen1-1-zen running: yes
Network: Device-1: Intel Ethernet I217-LM vendor: Hewlett-Packard driver: e1000e v: kernel port: f080
bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB driver: r8188eu
bus-ID: 3-6:4 chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
IF: wlp0s20u6 state: down mac: <filter>
Drives: Local Storage: total: 465.76 GiB used: 73.95 GiB (15.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS725050A7E630 size: 465.76 GiB
serial: <filter> rev: A380 scheme: GPT
Partition: ID-1: / raw-size: 238.71 GiB size: 238.71 GiB (100.00%) used: 73.93 GiB (31.0%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.5 MiB (26.6%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 238.71 GiB size: 238.71 GiB (100.00%) used: 73.93 GiB (31.0%) fs: btrfs
ID-4: /var/log raw-size: 238.71 GiB size: 238.71 GiB (100.00%) used: 73.93 GiB (31.0%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-5: /var/tmp raw-size: 238.71 GiB size: 238.71 GiB (100.00%) used: 73.93 GiB (31.0%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 378.5 MiB (4.8%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 52.0 C mobo: 27.8 C
Info: Processes: 219 Uptime: 59m wakeups: 0 Memory: 7.66 GiB used: 3.91 GiB (51.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1813 pacman: 1801
lib: 538 flatpak: 12 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.08System: Kernel: 5.15.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
date: 07/13/2015
direct render: Yes
inxi: 3.3.08
