Hello Garuda users.
I installed the gnome edition yesterday and tried to install 2 different themes and they both dont apply correctly.
The themes was installed via the software center
Default
Dracula Theme
Nordic Theme
Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=fb4f8752-5778-428b-984d-80e7a1caddca rw [email protected]
loglevel=3 ibt=off
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop System: Micro-Star product: MS-7B17 v: 2.0
Mobo: Micro-Star model: MPG Z390 GAMING EDGE AC (MS-7B17) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.70
date: 01/02/2020
Device-1: ps-controller-battery-70:20:84:50:6b:9f model: N/A serial: N/A
charge: N/A status: full
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3774 high: 5000 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3600 2: 3600 3: 3600
4: 5000 5: 4986 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600
13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 115200
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f06 class-ID: 0300
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-0 res: 3440x1440 dpi: 109 size: 800x330mm (31.5x12.99")
diag: 865mm (34.07") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 2060
SUPER/PCIe/SSE2 direct-render: Yes
driver: snd_hda_intel v: kernel bus-ID: 1-3.2:6 chip-ID: 054c:09cc
class-ID: 0300 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Sony DualShock 4 [CUH-ZCT2x] type: USB
driver: playstation,snd-usb-audio,usbhid
Device-4: EVGA NU Audio type: USB driver: snd-usb-audio bus-ID: 5-1:2
chip-ID: 3842:3100 class-ID: fe01
API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api tools: N/A
Device-2: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
driver: btusb v: 0.8 bus-ID: 1-14:9 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 6.8 TiB used: 615.23 GiB (8.8%)
model: WDS100T3XHC-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 102000WD temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Zotac model: ZTSSD-A5P-480G-PE
type: SSD serial: <filter> rev: 01.6 scheme: GPT
model: WD6003FZBX-00K5WB0 size: 5.46 TiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
used: 615.23 GiB (66.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.74 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C pch: 59.0 C mobo: N/A gpu: nvidia
temp: 49 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 404 Uptime: 4h 45m wakeups: 1 Memory: 62.74 GiB
used: 7.68 GiB (12.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1295
libs: 393 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.26
System install date: 2023-05-09
Last full system update: 2023-05-09
Is partially upgraded: Yes
Please help thanks all
