Theme Problems
i did and reboot my system.
Yes, and…? How are things?
As I said, everything seems fine now, the only problem is that there is no problem in my games, but windows and window effects are very laggy.
and that is with the kernel parameter?
Yes with this kernel paramter
Does the same lag happen in both X11 and Wayland sessions with these new settings?
Not Waylande, only x11 very laggy
Other than this problem, I have almost no problems. Screen 1 was not visible in Discord, now even that is visible
In the x11-session, try a restart of the display server with ctrl+alt+backspace.
Post the output from
inxi -G
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: nvidia
v: 545.29.06
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3 driver: X:
loaded: nvidia unloaded: modesetting gpu: nvidia,nvidia-nvswitch
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nvidia,swrast
platforms: gbm,x11,surfaceless,device
renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
API: Vulkan v: 1.3.274 drivers: nvidia surfaces: xcb,xlib
Looks good.
Try playing around with the nvidia settings, especially with the compositor.
I researched on the internet and realized that X11 causes a lot of problems with nvidia graphics cards. Since I can’t go back to plasma, I think the only solution is to change the distribution. Garuda is a distribution that I like very much and if I had an AMD graphics card I would never give it up :confused:
Don’t trust the net :smiley:
BTW, it depends on the Nvidia GPU and the DE, I have no problems with 1060, 3060 with X11/wayland on i3wm/KDE/Hyprland. You must check in each DE, which one work better for you X11 or wayland.
X11 has a not problem but very laggy. Wayland has a problems but don’t laggy hahahaa
Just use MXLinux or Mint :wink:
Here is nothing laggy.
I will use fedora because i want customization.
I read it is very laggy :smiley:
I’ve used Fedora before and it didn’t cause any problems. My computer is not bad anyway. My only problem is that I think some DEs are having problems with my graphics card.
I am not sure, but it may have more to do with the version of the driver than the distro. A lot of users have reported major issues with the 545 version of the Nvidia driver, including systems becoming more or less completely broken even though they had been fine on 535. If Fedora is working fine it may be because they are not yet using the 545 driver.
