Hello,
I have installed Garuda Gnome. Everything works perfectly. Except for the applications that go in the "system tray", such as "Telegram".
I searched "systray problem", "system tray error". But most of the articles talk about the KDE version.
Do you also have this problem?
Thank you very much for your insights.
Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4069e090-f73c-479e-b7bc-2c8fccf8481c rw rootflags=subvol=@
resume=UUID=fb8fe21a-7b6e-4792-927c-ec25b1d68e57 loglevel=3
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.37 info: latte-dock wm: gnome-shell
dm: GDM v: 43.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <superuser required>
UEFI: American Megatrends v: F32 date: 01/18/2021
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3778 high: 4342 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3809 2: 3651
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 4324 9: 3600 10: 3610 11: 4342
12: 3600 13: 3611 14: 4001 15: 4304 16: 3600 bogomips: 114985
Device-1: NVIDIA TU104GL [Quadro RTX 4000] driver: nvidia v: 525.89.02
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 07:00.0
chip-ID: 10de:1eb1 class-ID: 0300
Device-2: Logitech QuickCam Pro 9000 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3.2:5 chip-ID: 046d:0990
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-4 res: 3440x1440 hz: 60 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
missing.
Device-1: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel
bus-ID: 1-3.2:5 pcie: chip-ID: 046d:0990 gen: 1 speed: 2.5 GT/s
class-ID: 0102 serial: <filter> lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 07:00.1 chip-ID: 10de:10f8 class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech QuickCam Pro 9000 type: USB
Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 7-3.6:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp9s0f3u3u6 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-3.4:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 3.78 TiB used: 17.7 GiB (0.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SUV500120G
size: 111.79 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 56R6 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Generic model: UDISK
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 8.07 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 3.59 TiB size: 3.59 TiB (100.00%) used: 17.69 GiB (0.5%)
ID-3: /home raw-size: 3.59 TiB size: 3.59 TiB (100.00%)
used: 17.69 GiB (0.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 3.59 TiB size: 3.59 TiB (100.00%)
ID-5: /var/tmp raw-size: 3.59 TiB size: 3.59 TiB (100.00%)
ID-1: swap-1 type: zram size: 46.99 GiB used: 1024 KiB (0.0%)
ID-2: swap-2 type: partition size: 51.69 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.1 C mobo: 34.0 C gpu: nvidia temp: 50 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 386 Uptime: 16m wakeups: 1 Memory: 46.99 GiB
used: 4.59 GiB (9.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: dpkg
pkgs: 0 pm: pacman pkgs: 1523 libs: 392 tools: pamac,paru Shell: fish
v: 3.6.0 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-20
Last full system update: 2023-03-20
