Hello Garuda users I'm trying to delete files and folders off my attached USB devices but it's not helping, I don't get any errors though but the files and folders dont get deleted.
if I try the same file on my other Linux Distro Elementary OS Loki on my other SSD the proces goes well and the files or folders gets deleted
this is the command I'm running trying trying to delete write protected files and folders:
sudo rm -f -r -d /media/object-undefined/57689090-24a1-4794-9203-d659d13db8cd/media/
Hers my System info
Kernel: 5.15.64-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=fd064626-5c5f-4be1-9f81-5f6ac8b2f47d rw rootflags=subvol=@
resume=UUID=d8ae0431-a1a2-48e5-b320-073dd2566394 loglevel=3
Type: Desktop System: HP product: HP ProDesk 600 G2 DM v: N/A
serial: <superuser required> Chassis: type: 15 serial: <superuser required>
Mobo: HP model: 8169 v: KBC Version 05.26 serial: <superuser required>
UEFI: HP v: N22 Ver. 02.09 date: 03/10/2016
Info: model: Intel Core i5-6500T bits: 64 type: MCP arch: Skylake-S
gen: core 6 built: 2015 process: Intel 14nm family: 6 model-id: 0x5E (94)
stepping: 3 microcode: 0xF0
desc: 1x6 MiB
Speed (MHz): avg: 2827 high: 2993 min/max: 800/3100 scaling:
driver: intel_pstate governor: performance cores: 1: 2993 2: 2947 3: 2864
4: 2507 bogomips: 19999
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
prctl and seccomp
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI1 model: Mi Monitor serial: <filter>
built: 2020 res: 1920x1080 dpi: 92 gamma: 1.2
size: 530x290mm (20.87x11.42") diag: 603mm (23.7") ratio: 16:9 modes:
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.64-1-lts running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-4: PipeWire v: 0.3.57 running: yes
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
Device-2: TP-Link TL-WN823N v2/v3 [Realtek RTL8192EU] type: USB
driver: rtl8xxxu bus-ID: 1-5:3 chip-ID: 2357:0109 class-ID: 0000
IF: wlp0s20f0u5 state: up mac: <filter>
Local Storage: total: 617.64 GiB used: 190.01 GiB (30.8%)
model: MZVLB512HAJQ-000L7 size: 476.94 GiB block-size: physical: 512 B
rev: 4L2QEXA7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: TCSunBow model: X3 120GB
type: SSD serial: <filter> rev: 8A scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Lexar model: USB Flash
Drive size: 28.91 GiB block-size: physical: 512 B logical: 512 B
type: SSD serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 468.5 GiB size: 468.5 GiB (100.00%) used: 178.13 GiB
(38.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 578 KiB
ID-3: /home raw-size: 468.5 GiB size: 468.5 GiB (100.00%) used: 178.13
GiB (38.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 468.5 GiB size: 468.5 GiB (100.00%) used: 178.13
ID-5: /var/tmp raw-size: 468.5 GiB size: 468.5 GiB (100.00%) used: 178.13
ID-1: swap-1 type: zram size: 7.65 GiB used: 564.2 MiB (7.2%)
ID-2: swap-2 type: partition size: 8.18 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 47.0 C pch: 52.0 C mobo: N/A
Processes: 227 Uptime: 5h 2m wakeups: 0 Memory: 7.65 GiB used: 4.21 GiB
(55.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 1417 lib: 349
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2021-09-24
Last full system update: 2022-09-04
Snapshots: Timeshift (maybe)
Failed units: bluetooth-autoconnect.service systemd-guest-user.service
