Hi guys, it's been a while since I've been using garuda linux and have encountered and terminated a lot of issues with the help of this forum, but the current issue I'm facing doesn't seem to appear with a lot of people on the forum and hence I have not been able to find any solution. The problem is that after a recent update, my terminal which should normally look similar to
https://forum.garudalinux.org/uploads/default/original/2X/2/2e42c197f0b60b2508d150f030702d001b6166e0.jpeg
instead shows
-` kratoes669@kompyuter
.o+` --------------------
`ooo/ OS: Arch Linux x86_64
`+oooo: Host: 82EY IdeaPad Gaming3 15ARH05D
`+oooooo: Kernel: 6.0.6-zen1-1-zen
-+oooooo+: Uptime: 23 mins
`/:-:++oooo+: Packages: 1744 (pacman)[stable], 10 (snap)
`/++++/+++++++: Shell: fish 3.5.1
`/++++++++++++++: Resolution: 1920x1080
`/+++ooooooooooooo/` DE: GNOME 42.5
./ooosssso++osssssso+` WM: Mutter (X11)
.oossssso-````/ossssss+` WM Theme: Orchis-Dark-Compact
-osssssso. :ssssssso. Theme: [Plasma], {?}Orchis-Dark-Compact [GTK2/3/4]
:osssssss/ osssso+++. Icons: Tela-circle-black-dark [GTK2/3/4]
/ossssssss/ +ssssooo/- Terminal: gnome-terminal-server
/ossssso+/:- -:/+osssso+- Terminal Font: FantasqueSansMono Nerd Font Mono 12
+sso+:-
.-/+oso: CPU: AMD Ryzen 5 4600H (12) @ 3 GHz
-/+/ GPU: AMD Renoir
/ GPU: NVIDIA TU117M
Memory: 4.41 GiB / 7.14 GiB
That is the OS is changed to arch linux and moreover the splash screen too shows the boot os as arch linux. I know that garuda is based on arch but this was not the default appearance of the terminal and I liked that one better. the output of garuda-inxi is pasted below.
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=5961e08e-efa9-4ac9-a358-63955349c888 rw rootflags=subvol=@
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Distro: Arch Linux
Type: Laptop System: LENOVO product: 82EY v: IdeaPad Gaming3 15ARH05D
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming3 15ARH05D
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
serial: <superuser required> UEFI: LENOVO v: FCCN18WW date: 04/14/2022
ID-1: BAT0 charge: 39.6 Wh (100.0%) condition: 39.6/45.0 Wh (88.0%)
volts: 12.8 min: 11.4 model: SMP L19M3PF7 type: Li-poly serial: <filter>
status: full cycles: 447
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7
(7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1399 high: 1400 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1400 2: 1400
3: 1400 4: 1400 5: 1397 6: 1400 7: 1400 8: 1400 9: 1400 10: 1397 11: 1400
12: 1400 bogomips: 71865
protection
Device-1: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 520.56.06
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-10) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 40.0 C
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 04f2:b6c2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x15e7 built: 2016
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:c822
IF-ID-1: CloudflareWARP state: unknown speed: 10 Mbps duplex: full
mac: N/A
bus-ID: 3-3:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Local Storage: total: 1.6 TiB used: 180.08 GiB (11.0%)
model: MZALQ256HAJD-000L2 size: 238.47 GiB block-size: physical: 512 B
rev: AL2QFXV7 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 2E scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: A-Data model: SC685
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: SSD
serial: <filter> rev: 9301 scheme: GPT
ID-1: / raw-size: 195.65 GiB size: 195.65 GiB (100.00%) used: 52.3 GiB
(26.7%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 748 KiB
(0.1%) fs: vfat dev: /dev/sdb2 maj-min: 8:18
ID-3: /home raw-size: 195.65 GiB size: 195.65 GiB (100.00%) used: 52.3
GiB (26.7%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-4: /var/log raw-size: 195.65 GiB size: 195.65 GiB (100.00%) used: 52.3
ID-5: /var/tmp raw-size: 195.65 GiB size: 195.65 GiB (100.00%) used: 52.3
ID-1: swap-1 type: zram size: 7.14 GiB used: 567.8 MiB (7.8%)
System Temperatures: cpu: 41.8 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 358 Uptime: 16m wakeups: 1 Memory: 7.14 GiB used: 4.51 GiB
(63.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1744
libs: 399 tools: gnome-software,pamac,paru Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-10-14
Last full system update: 2022-10-31 ↻
Failed units: intel-undervolt.service
