Uploading: Captura de pantalla_20250417_194248.png…
Hi, could someone help me with this problem? The kernels don’t load. I waited half an hour and they didn’t load.
hi jimmy369,
how did you installed other Kernels? Can you start another Kernel or Fallback in the options?
Did you try to load the last snapshot or any snapshot?
Your picture upload dosnt work here still say Uploading: Captura de … but the link dont work.
Normally one issue per Topic so meant open a new Topic that more people see it. This already solved so no other may watch it again. Thanks
@jimmy369: Please follow the forum rules and the topic template - ONE issue per topic.
I have moved your post to a new thread.
btw: you should wait until the pic has been uploaded before posting.
If you can’t figure out how to take screenshots yourself, you better not install another kernel.
Here again all the help from the template you deleted in your first post.
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Thanks for responding, I’m giving up. There are many things that need to be fixed. Good luck. Goodbye. I won’t bother you with my questions anymore.
There is no reason to give up and you are not bothering anyone here with your questions. You just need to explain yourself better and you should answer the questions you are asked. Without helpful information on your part and without garuda-inxi`, no one can help you.
If you change your mind then just let us know and we will open this topic again.
