Hello Garuda users & devs!
I have Garuda KDE Dr460nized installed. I really like this distro, but I have one serious (just for me) problem.
My hobby is writing game plugins for the old Counter-Strike 1.6 game. I run this game with Proton. (Steam version and standalone version, called PortProton). I often have to minimize the game to test it.
And the problem is that sometimes, after minimizing the game, the system interface becomes broken. The game window becomes small and black - there is no picture. Window switching (alt+tab), switching between applications in Latte Dock does not work.
Even if I manage to launch the terminal or the system monitor and close the game process, the problem remains. Only rebooting the PC helps.
You might think it's only because of proton. BUT. I usually use VLC as a video player, but a few times I had to use MPV.
And once I ran into exactly the same problem when minimizing (or exiting full screen mode) a full screen MPV!
I am willing to provide the necessary information if needed.
I hope for your help, I really do not want to install another distro.
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=ec94e14c-f305-4bd1-aae7-2037238162d6 rw [email protected]
resume=UUID=a915aef2-ea70-4a51-8371-3b8058faddb9 loglevel=3 ibt=off
Type: Desktop System: HUANANZHI X99 product: N/A v: NALEX
Mobo: HUANANZHI model: X99-BD4 v: V1.1, NALEX serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: 5.11 date: 11/01/2020
Info: model: Intel Xeon E5-2666 v3 bits: 64 type: MT MCP arch: Haswell
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3F (63) stepping: 2 microcode: 0x49
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 3492 high: 3500 min/max: 1200/3500 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3492 2: 3492 3: 3492
4: 3492 5: 3492 6: 3492 7: 3492 8: 3492 9: 3494 10: 3492 11: 3492 12: 3492
13: 3492 14: 3492 15: 3492 16: 3491 17: 3493 18: 3500 19: 3498 20: 3492
bogomips: 115732
vulnerable
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] driver: nvidia v: 525.60.11
alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.0 chip-ID: 10de:2482
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 110 s-size: 795x333mm (31.30x13.11")
s-diag: 862mm (33.93")
Monitor-1: DP-2 pos: primary res: 3440x1440 dpi: 109
size: 800x330mm (31.5x12.99") diag: 865mm (34.07") modes: N/A
Monitor-2: HDMI-0 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce RTX 3070
Ti/PCIe/SSE2 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 3-5:3 chip-ID: 0c76:1617
Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device type: USB
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.18 TiB used: 791.26 GiB (65.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NX-512 size: 476.94 GiB
type: SSD serial: <filter> rev: SN08381 temp: 35.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS721025CLA682
type: HDD rpm: 7200 serial: <filter> rev: A41A scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB model: USB DISK 2.0 size: 28.88 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: PMAP scheme: MBR
ID-1: / raw-size: 442.62 GiB size: 442.62 GiB (100.00%)
used: 265.18 GiB (59.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 442.62 GiB size: 442.62 GiB (100.00%)
ID-3: /var/log raw-size: 442.62 GiB size: 442.62 GiB (100.00%)
ID-4: /var/tmp raw-size: 442.62 GiB size: 442.62 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 257.5 MiB (0.8%)
ID-2: swap-2 type: partition size: 34.31 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 22.0 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 458 Uptime: 48m wakeups: 0 Memory: 31.25 GiB
used: 10.03 GiB (32.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: 1993 pm: pacman pkgs: 1985
libs: 548 tools: octopi,pamac,paru pm: flatpak pkgs: 8 Shell: fish v: 3.5.1
running-in: konsole inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-08-31
Last full system update: 2022-12-08
