That multi monitor thing with RDR2 post Jan 2024
After RockStar’s end of January update to RDR2 I started to experience this trifling problem, when I try to run RDR2 with all my monitors connected and enabled the loading gets to the grey progress bar being half way along and just sits there, I can work around this by disabling two of my monitors in display settings and then powering them off, then RDR2 loads all they way in and runs just as well as it used to before RockStar’s “helpful” update but as I need all monitors for my usual work flows this is a royal p.i.t.a.
Valve and RockStar have both been as useful as a chocolate ashtray in this matter so I thought to ask here just in case any others have had this happen. Any hints or indeed clues would be most welcome, thanks. :slight_smile:
╭─malcolm@ScipioAfricanus in ~
╰─λ garuda-inxi
Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=971d3b21-22d7-4046-afa5-863c95801f98 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B450 GAMING PLUS MAX (MS-7B86) v: 3.0
Megatrends LLC. v: H.G0 date: 07/26/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2343 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2200 2: 2430
3: 2430 4: 2200 5: 2200 6: 2200 7: 3800 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2430 15: 2200 16: 2200 bogomips: 121598
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-2,DP-3 empty: HDMI-A-1 bus-ID: 28:00.0
chip-ID: 1002:73df class-ID: 0300
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1520x285mm (59.84x11.22")
s-diag: 1546mm (60.89")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: right model: Philips PHL 241E1
serial: <filter> built: 2023 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
Monitor-2: DP-2 mapped: DisplayPort-1 pos: left model: Philips PHL 241E1
Monitor-3: DP-3 mapped: DisplayPort-2 pos: primary,center
model: Acer ED322QR serial: <filter> built: 2019 res: 1920x1080 dpi: 70
gamma: 1.2 size: 700x390mm (27.56x15.35") diag: 801mm (31.5") ratio: 16:9
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.1-arch1.1
navi22 LLVM 16.0.6 DRM 3.57 6.7.6-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.3.276 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.1-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 28:00.1 chip-ID: 1002:ab28
bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: off with: 1: wireplumber status: off
2: pw-jack type: plugin tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
Local Storage: total: 8.19 TiB used: 1.15 TiB (14.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3SSD8
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 27.9 C
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Crucial model: CT1000P2SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR033 temp: 23.9 C
scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000BX500SSD1
tech: SSD serial: <filter> fw-rev: 061 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ABA100
tech: HDD rpm: 5700 serial: <filter> fw-rev: A720 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20EZRX-00D8PB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000DM003-9YN162
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC4B scheme: MBR
ID-1: / raw-size: 133.01 GiB size: 133.01 GiB (100.00%)
used: 32.91 GiB (24.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 14.65 GiB size: 14.63 GiB (99.90%)
used: 608 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 1.47 TiB size: 3.29 TiB (223.88%)
used: 1.11 TiB (33.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /usr raw-size: 147.45 GiB size: 147.45 GiB (100.00%)
used: 8.07 GiB (5.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/log raw-size: 133.01 GiB size: 133.01 GiB (100.00%)
ID-6: /var/tmp raw-size: 133.01 GiB size: 133.01 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.26 GiB used: 13.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 64 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 40.5 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 28.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 422
Memory: total: 32 GiB available: 31.26 GiB used: 5.47 GiB (17.5%)
Processes: 391 Power: uptime: 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1922 libs: 553 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2023-03-25
Last full system update: 2024-02-24
Does this also happen under Wayland? it looks like you are running X11 atm
Have you tried switching between settings like fullscreen and borderless fullscreen?
RDR2 seems to be working fine for me. I only have 2 monitors (and the second was only plugged in for the test). But I got to the actual gameplay part fine. I’m on X11 with an AMD GPU.
Maybe the game didn’t update right. I have it through the Rockstar launcher and that process isn’t very intuitive. I used the verify game file integrity" option, since that’s what someone recommended online. My current game version is 1.0.1491.18.
I’d be happy to do more testing to help narrow down the issue, but I only have the two monitors. If you have a newer game version, I can look into other ways to try and update.
Thanks for the reply, apologies for the delay coming back but I got stuck down a deep rabbit hole with the firmware for my 3d printer’s new mother board … turned out to be a typo hidden in the source code for it from BTT’s web site … good news is that the update to Proton GE 9 beta has fixed all my RDR2 woes, an earlier system update with a shift to Wayland let it run once but then returned to single monitor use. Thankfully the custom G E proton got the job done. atb MWW
Thanks for the offer thankfully as you can see from the above post it is all sorted now. Cheers folks! :slight_smile:
