TF2 Does Not Launch
Hi again, I’m having difficulty getting TF2 to launch. Attempting to launch the game appears to cause nothing to happen.
After running TF2 with %command% &> ~/tf2log.txt as the launch options, it generated this as the output of tf2log.txt:
ERROR: ld.so: object '/home/aidan/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
ERROR: ld.so: object '/home/aidan/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
pid 22768 != 22767, skipping destruction (fork without exec?)
src/tcmalloc.cc:278] Attempt to free invalid pointer 0xa737ad0
/home/aidan/.local/share/Steam/steamapps/common/Team Fortress 2/hl2.sh: line 72: 22770 Aborted                 (core dumped) ${GAME_DEBUGGER} "${GAMEROOT}"/${GAMEEXE} "$@"
Here is my input from garuda-inxi:
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0c56ec49-20ad-4aa0-a88b-55b47e733bc9 rw rootflags=subvol=@
quiet rd.luks.uuid=d79b9435-2941-4ab1-b7b1-6436232809f7
rd.luks.uuid=49c27010-0fe7-452f-b43e-2b305ff69240
resume=/dev/mapper/luks-49c27010-0fe7-452f-b43e-2b305ff69240 loglevel=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASRock model: 970M Pro3 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P1.50 date: 01/11/2016
Info: model: AMD FX-4350 bits: 64 type: MT MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 192 KiB
desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1396 high: 1397 min/max: 1400/4200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1396 2: 1397
3: 1397 4: 1396 bogomips: 33526
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: Tul / PowerColor driver: amdgpu
v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20
pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 52.0 C
gpu: amdgpu display-ID: 0
drv: radeonsi inactive: gbm
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 560 Series (polaris11
LLVM 16.0.6 DRM 3.54 6.6.4-zen1-1-zen) device-ID: 1002:67ef
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 560 Series (RADV POLARIS11) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:67ef surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: AMD SBx00 Azalia vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Tul / PowerColor driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aae0 class-ID: 0403
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api with: aoss
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 14e4:43a0 class-ID: 0280
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 2357:0604
Local Storage: total: 931.51 GiB used: 222.32 GiB (23.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
used: 222.32 GiB (24.1%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-d79b9435-2941-4ab1-b7b1-6436232809f7
ID-2: /home raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-3: /var/log raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-4: /var/tmp raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-0 maj-min: 254:0
mapped: luks-49c27010-0fe7-452f-b43e-2b305ff69240
ID-2: swap-2 type: zram size: 7.73 GiB used: 1.43 GiB (18.5%)
System Temperatures: cpu: 16.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 982
Processes: 284 Uptime: 46m wakeups: 0 Memory: total: 8 GiB
available: 7.73 GiB used: 4.32 GiB (55.9%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1890 libs: 508 tools: octopi,paru,yay Shell: fish
v: 3.6.2 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-27
Last full system update: 2023-12-05
Thanks.
Could be this bug (try the suggested workaround)
https://www.protondb.com/app/440#F5eUgPqkSk
Which was mentioned here
If workaround doesn’t help, try logging to an x11 session.
Apologies, I see multiple workarounds in that thread. Which one are you referring to?
Edit: Nevermind, I figured it out. You need to install lib32-gperftools and then set your launch options to LD_PRELOAD=/usr/lib32/libtcmalloc.so %command%
