Kernel: 5.18.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=e08ba235-2d5b-4752-aa8a-d6235cb506f3 rw [email protected]
resume=UUID=7b1d8874-5890-4209-abcb-ae4c25bdcc93 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: Micro-Star model: B450M PRO-M2 MAX (MS-7B84) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.70
date: 06/10/2020
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3609 high: 4069 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3670 2: 3601
3: 3596 4: 3591 5: 3563 6: 4069 7: 3585 8: 3562 9: 3622 10: 3600 11: 3344
12: 3587 13: 3581 14: 3565 15: 3609 16: 3599 bogomips: 124801
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 515.57
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 29:00.0
chip-ID: 10de:1f82 class-ID: 0300
Device-2: Sunplus Innovation FULL HD webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:2283
Screen-1: 0 s-res: 4920x2160 s-dpi: 156 s-size: 801x352mm (31.54x13.86")
s-diag: 875mm (34.45")
Monitor-1: DP-0 pos: primary,right res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.58") diag: 698mm (27.49") modes: N/A
Monitor-2: DP-2 pos: primary,left res: 1080x1920 hz: 60 dpi: 96
size: 286x509mm (11.26x20.04") diag: 584mm (22.99") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 1-2:5 pcie:
chip-ID: 18d1:4ee8 gen: 3 class-ID: 0103 speed: 8 GT/s lanes: 16
serial: <filter> bus-ID: 29:00.1 chip-ID: 10de:10fa class-ID: 0403
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Google Nexus/Pixel Device (MIDI) type: USB
Device-4: Sunplus Innovation FULL HD webcam type: USB
Sound Server-1: ALSA v: k5.18.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-657335f7a75a state: down mac: <filter>
bus-ID: 1-3:2 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 5.46 TiB used: 260.26 GiB (4.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105
temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 175.44 GiB size: 175.44 GiB (100.00%)
used: 58.02 GiB (33.1%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 350.3 MiB size: 349.5 MiB (99.80%)
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
used: 202.24 GiB (74.0%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 175.44 GiB size: 175.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 175.44 GiB size: 175.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 21.5 MiB (0.1%)
ID-2: swap-2 type: partition size: 15.82 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 439 Uptime: 1h 59m wakeups: 0 Memory: 31.3 GiB
used: 13.42 GiB (42.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 alt: 11 clang: 14.0.6 Packages:
pacman: 2218 lib: 554 Shell: fish v: 3.4.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-06-07
Last full system update: 2022-07-13 ↻
I recently installed:
https://aur.archlinux.org/packages/texlive-full
However, I also use pandoc
, which has haskell-citeproc
as a dependency.texlive-full
provides haskell-citeproc
, which is why it should be fine running pandoc
in an installation with texlive-full
, without having to worry about haskell-citeproc
; not the case here.
citeproc
is used for bibliography, so when I try to run:
pandoc -s abstract.tex --citeproc --bibliography=abstract.bib -o main.docx
I get:
pandoc: error while loading shared libraries: libHSciteproc-0.7-EQGOLZMoJ4pEvFqsVgDGMq-ghc9.0.2.so: cannot open shared object file: No such file or directory
Which means pandoc
cannot find citeproc
. As mentioned, I have citeproc
(installed as haskell-citeproc
[🔍] × which citeproc
/usr/bin/citeproc
When I roll back the texlive-full
install, the pandoc
command runs fine. I have tried to reinstall pandoc
after installing texlive-full
, didn't help.
