I have been removing some old software from my laptop. I have just tried to update it and got the following message. Have I screwed something up?
[sudo] password for colin:
:: Synchronising package databases...
garuda is up to date
core 132.5 KiB 13.0 KiB/s 00:10 [------------------------------------] 100%
extra 8.2 MiB 260 KiB/s 00:32 [------------------------------------] 100%
multilib 141.3 KiB 13.8 KiB/s 00:10 [------------------------------------] 100%
chaotic-aur 2.6 MiB 134 KiB/s 00:20 [------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
resolving dependencies...
:: There are 128 providers available for tessdata:
:: Repository extra
1) tesseract-data-afr 2) tesseract-data-amh 3) tesseract-data-ara 4) tesseract-data-asm
5) tesseract-data-aze 6) tesseract-data-aze_cyrl 7) tesseract-data-bel 8) tesseract-data-ben
9) tesseract-data-bod 10) tesseract-data-bos 11) tesseract-data-bre 12) tesseract-data-bul
13) tesseract-data-cat 14) tesseract-data-ceb 15) tesseract-data-ces 16) tesseract-data-chi_sim
17) tesseract-data-chi_sim_vert 18) tesseract-data-chi_tra 19) tesseract-data-chi_tra_vert
20) tesseract-data-chr 21) tesseract-data-cos 22) tesseract-data-cym 23) tesseract-data-dan
24) tesseract-data-dan_frak 25) tesseract-data-deu 26) tesseract-data-deu_frak 27) tesseract-data-div
28) tesseract-data-dzo 29) tesseract-data-ell 30) tesseract-data-eng 31) tesseract-data-enm
32) tesseract-data-epo 33) tesseract-data-equ 34) tesseract-data-est 35) tesseract-data-eus
36) tesseract-data-fao 37) tesseract-data-fas 38) tesseract-data-fil 39) tesseract-data-fin
40) tesseract-data-fra 41) tesseract-data-frk 42) tesseract-data-frm 43) tesseract-data-fry
44) tesseract-data-gla 45) tesseract-data-gle 46) tesseract-data-glg 47) tesseract-data-grc
48) tesseract-data-guj 49) tesseract-data-hat 50) tesseract-data-heb 51) tesseract-data-hin
52) tesseract-data-hrv 53) tesseract-data-hun 54) tesseract-data-hye 55) tesseract-data-iku
56) tesseract-data-ind 57) tesseract-data-isl 58) tesseract-data-ita 59) tesseract-data-ita_old
60) tesseract-data-jav 61) tesseract-data-jpn 62) tesseract-data-jpn_vert 63) tesseract-data-kan
64) tesseract-data-kat 65) tesseract-data-kat_old 66) tesseract-data-kaz 67) tesseract-data-khm
68) tesseract-data-kir 69) tesseract-data-kmr 70) tesseract-data-kor 71) tesseract-data-kor_vert
72) tesseract-data-lao 73) tesseract-data-lat 74) tesseract-data-lav 75) tesseract-data-lit
76) tesseract-data-ltz 77) tesseract-data-mal 78) tesseract-data-mar 79) tesseract-data-mkd
80) tesseract-data-mlt 81) tesseract-data-mon 82) tesseract-data-mri 83) tesseract-data-msa
84) tesseract-data-mya 85) tesseract-data-nep 86) tesseract-data-nld 87) tesseract-data-nor
88) tesseract-data-oci 89) tesseract-data-ori 90) tesseract-data-pan 91) tesseract-data-pol
92) tesseract-data-por 93) tesseract-data-pus 94) tesseract-data-que 95) tesseract-data-ron
96) tesseract-data-rus 97) tesseract-data-san 98) tesseract-data-sin 99) tesseract-data-slk
100) tesseract-data-slk_frak 101) tesseract-data-slv 102) tesseract-data-snd 103) tesseract-data-spa
104) tesseract-data-spa_old 105) tesseract-data-sqi 106) tesseract-data-srp
107) tesseract-data-srp_latn 108) tesseract-data-sun 109) tesseract-data-swa 110) tesseract-data-swe
111) tesseract-data-syr 112) tesseract-data-tam 113) tesseract-data-tat 114) tesseract-data-tel
115) tesseract-data-tgk 116) tesseract-data-tgl 117) tesseract-data-tha 118) tesseract-data-tir
119) tesseract-data-ton 120) tesseract-data-tur 121) tesseract-data-uig 122) tesseract-data-ukr
123) tesseract-data-urd 124) tesseract-data-uzb 125) tesseract-data-uzb_cyrl 126) tesseract-data-vie
127) tesseract-data-yid 128) tesseract-data-yor
Enter a number (default=1):
Here’s my system specs:
```text
Kernel: 6.5.9-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=e0aa6bf1-e32d-48b2-a659-01e4322f83f8 rw rootflags=subvol=@ quiet quiet
resume=UUID=31f5f81c-4fb3-4a39-893a-3e7c25a0feb6 loglevel=3 ibt=off
Desktop: GNOME v: 45.0 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA v: 1.0
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
v: X513UA.312 date: 04/26/2022
ID-1: BAT0 charge: 9.4 Wh (23.9%) condition: 39.4/42.1 Wh (93.7%) power: 5.4 W volts: 11.8
min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging cycles: 565
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 649 high: 1397 min/max: 400/4056 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 1397 3: 1397 4: 400 5: 400 6: 400 7: 400 8: 1397 9: 400
10: 400 11: 400 12: 400 bogomips: 50301
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 39.0 C
Device-2: Quanta [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 compositor: gnome-shell
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD Radeon Graphics
(RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2 device-ID: 1002:164c
surfaces: xcb,xlib,wayland device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
Server-1: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
IF-ID-1: enp3s0f3u3 state: up speed: 150 Mbps duplex: half mac: <filter>
Device-1: Realtek [] driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 1-2:2 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10 status: discoverable: no
pairing: no
Device-2: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0032 class-ID: e001
Report: ID: hci1 rfk-id: 3 state: down bt-service: enabled,running rfk-block: hardware: no
software: yes address: <filter> bt-v: 5.3 lmp-v: 12 status: discoverable: no pairing: no
Local Storage: total: 476.94 GiB used: 20.07 GiB (4.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-00000 size: 476.94 GiB
fw-rev: FXV7101Q temp: 33.9 C scheme: GPT
ID-1: / raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 8.6 GiB (5.9%) fs: btrfs
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 321.45 GiB size: 321.45 GiB (100.00%) used: 11.46 GiB (3.6%) fs: btrfs
ID-4: /var/log raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 8.6 GiB (5.9%) fs: btrfs
ID-5: /var/tmp raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 8.6 GiB (5.9%) fs: btrfs
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: swap-2 type: zram size: 7.15 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
System Temperatures: cpu: 40.9 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (rpm): cpu: 0
Processes: 368 Uptime: 2h 15m wakeups: 1 Memory: total: 8 GiB note: est. available: 7.15 GiB
used: 3.34 GiB (46.8%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1368 libs: 403 tools: pamac,paru Client: shell wrapper
v: 5.2.15-release inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-26
Last full system update: 2023-10-31
Failed units: cpupower.service
