Kernel: 6.2.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=638d66f7-7120-495a-b112-8982a6bd72b5 rw [email protected]
resume=UUID=9e073d5e-7133-4096-96d4-c7f96f4ce63a loglevel=3 ibt=off
Desktop: Cinnamon v: 5.6.7 tk: GTK v: 3.24.37 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: GA-78LMT-USB3 6.0
serial: <superuser required> BIOS: Award v: F2 date: 11/25/2014
Info: model: AMD FX-6300 bits: 64 type: MT MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 6 smt: enabled cache: L1: 288 KiB
desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1488 high: 1696 min/max: 1400/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1406
3: 1616 4: 1696 5: 1406 6: 1406 bogomips: 42188
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1,DVI-D-1
bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 45.0 C
Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
s-diag: 414mm (16.31")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC 1970W serial: <filter>
built: 2015 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 15.0.7 DRM 3.49 6.2.2-zen1-1-zen) direct-render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aae0
Sound API: ALSA v: k6.2.2-zen1-1-zen running: yes
lanes: 1 port: ce00 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp0s19f2u4 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Xiaomi Mi/Redmi series (RNDIS) type: USB driver: rndis_host
v: kernel bus-ID: 3-4:3 chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 2.73 TiB used: 1.97 TiB (72.1%)
model: WD10EZRX-00L4HB0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
model: WD20EZBX-00AYRA0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-1: / raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
used: 546 GiB (59.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
ID-3: /var/log raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
ID-4: /var/tmp raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.66 GiB used: 435.2 MiB (3.6%)
ID-2: swap-2 type: partition size: 12.83 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 31.6 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1411
Processes: 304 Uptime: 45m wakeups: 0 Memory: 11.66 GiB
used: 6.58 GiB (56.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1858
pm: pacman pkgs: 1836 libs: 554 tools: octopi,pamac,paru pm: flatpak
pkgs: 22 Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-12-26
Last full system update: 2023-03-08
Failed units: nmb.service
i am having problem with Retroarch. Whenever i try to start retroarch just shut himself with error
retroarch --verbose
[INFO] [Config]: Looking for config in: "/home/jumbotron/.config/retroarch/retroarch.cfg".
[INFO] RetroArch 1.14.0 (Git ad89b0c655)
[INFO] === Build =======================================
[INFO] CPU Model Name: AMD FX(tm)-6300 Six-Core Processor
[INFO] Capabilities: MMX MMXEXT SSE SSE2 SSE3 SSE4 SSE4.2 AES AVX
[INFO] Built: Dec 13 2022
[INFO] Version: 1.14.0
[INFO] Git: ad89b0c655
[INFO] =================================================
[INFO] [Input]: Found input driver: "x".
[INFO] [Environ]: SET_PIXEL_FORMAT: RGB565.
[INFO] [Core]: Version of libretro API: 1, Compiled against API: 1
[INFO] [Audio]: Set audio input rate to: 48000.00 Hz.
[INFO] [Video]: Set video size to: 1280x720.
[INFO] [Video]: Starting threaded video driver ...
[ERROR] [Wayland]: Failed to connect to Wayland server.
[INFO] [GLX]: GLX_EXT_swap_control_tear supported.
[INFO] [GLCore]: Found GL context: "x".
[INFO] [GLCore]: Detecting screen resolution: 1366x768.
[INFO] [XINERAMA]: Xinerama version: 1.1.
[INFO] [XINERAMA]: Xinerama screens: 1.
[INFO] [GLX]: Using Xinerama on screen #0.
[INFO] [GLX]: X = 0, Y = 0, W = 1366, H = 768.
[INFO] [GLX]: Using windowed fullscreen.
[INFO] [GLX]: Creating context for requested version 3.2.
[INFO] [GLX]: Found swap function: glXSwapIntervalEXT.
[INFO] [GLCore]: Vendor: AMD, Renderer: AMD Radeon RX 550 / 550 Series (polaris12, LLVM 15.0.7, DRM 3.49, 6.2.2-zen1-1-zen).
[INFO] [GLCore]: Version: 4.6 (Core Profile) Mesa 22.3.6.
[INFO] [GLCore]: Using resolution 1366x768.
[INFO] [Joypad]: Found joypad driver: "udev".
[INFO] [GLCore]: Loading stock shader.
[INFO] [slang]: Building pass #0 (N/A)
[INFO] [GLCore]: Not using frame history.
[INFO] [GLCore]: Not using framebuffer feedback.
[INFO] [Video]: Found display server: "x11".
[INFO] [PulseAudio]: Requested 24576 bytes buffer, got 18432.
[INFO] [Display]: Found display driver: "glcore".
[INFO] [Playlist]: Loading history file: "/home/jumbotron/.config/retroarch/content_history.lpl".
[INFO] [Playlist]: Loading history file: "/home/jumbotron/.config/retroarch/content_music_history.lpl".
[INFO] [Playlist]: Loading history file: "/home/jumbotron/.config/retroarch/content_video_history.lpl".
[INFO] [Playlist]: Loading history file: "/home/jumbotron/.config/retroarch/content_image_history.lpl".
[INFO] [Playlist]: Loading favorites file: "/home/jumbotron/.config/retroarch/content_favorites.lpl".
[INFO] [PulseAudio]: Pausing.
[INFO] [GLX]: Resized fullscreen resolution to 1366x768.
[INFO] [XINERAMA]: Saved monitor #0.
[INFO] Threaded video stats: Frames pushed: 660, Frames dropped: 0.
[INFO] [Video]: Does not have enough samples for monitor refresh rate estimation. Requires to run for at least 4096 frames.
fish: Job 1, 'retroarch --verbose' terminated by signal SIGSEGV (Address boundary error)
After this it won't launch without restarting my pc .
