Hello, I have some issue with the front in fish? my terminal shows fuzzy letters.
inxi output
╭─algori@thmus in ~
╰─λ sudo garuda-inxi
[sudo] password for algori:
Kernel: 6.4.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=48637f32-6542-4b8d-9034-f859ede8855e rw
rootflags=subvol=@ quiet rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
resume=UUID=73407c84-654f-4dc0-9a0c-af4b77f8503c loglevel=3 ibt=off
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel
wm: bspwm v: 0.9.10 dm: LightDM v: 1.32.0 Distro: Garuda Linux
Type: Laptop System: Hewlett-Packard product: HP EliteBook Folio 9480m
v: A3009DD10303 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 22DA v: KBC Version 92.15
serial: <filter> UEFI: Hewlett-Packard v: M85 Ver. 01.33
date: 10/27/2015
ID-1: BAT0 charge: 32.3 Wh (95.8%) condition: 33.7/33.7 Wh (100.0%)
volts: 16.5 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i7-4600U socket: BGA1168 (U3E1) note: check
bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3 note: check
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x45 (69)
stepping: 1 microcode: 0x26
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2697 high: 3300 min/max: 800/3300
base/boost: 2100/3700 scaling: driver: intel_cpufreq
governor: performance volts: 0.7 V ext-clock: 100 MHz cores: 1: 3300
2: 3300 3: 2095 4: 2096 bogomips: 21549
Device-1: Intel Haswell-ULT Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-7.5
process: Intel 22nm built: 2013 ports: active: eDP-1 empty: DP-1,
DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
Device-2: Chicony HP HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-7:5 chip-ID: 04f2:b477
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-c4107
driver: X: loaded: intel unloaded: modesetting alternate: fbdev,vesa
dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96
s-size: 361x203mm (14.21x7.99") s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x14a4
built: 2014 res: 1366x768 hz: 60 dpi: 112 gamma: 1.2
size: 310x170mm (12.2x6.69") diag: 355mm (14") ratio: 16:9
modes: 1366x768
missing.
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard 8
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
API: ALSA v: k6.4.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: JACK v: 1.9.22 status: off tools: N/A
Server-2: PipeWire v: 0.3.75 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process) with:
1: pulseaudio-alsa type: plugin 2: pulseaudio-jack type: module
tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard
driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:155a
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:08b1
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:3
chip-ID: 8087:07dc class-ID: e001
address: <filter>
Local Storage: total: 238.47 GiB used: 60.64 GiB (25.4%)
SMART Message: Required tool smartctl not installed. Check
--recommends
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD7TB3Q-256G-1006
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0306 scheme: GPT
ID-1: / raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
used: 60.64 GiB (26.4%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 562 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 7.64 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 227 Uptime: 10m wakeups: 1 Memory: total: 8 GiB
available: 7.64 GiB used: 3.02 GiB (39.5%) igpu: 32 MiB Init: systemd
v: 253 default: graphical tool: systemctl Compilers: gcc: 13.1.1
clang: 15.0.7 Packages: pm: pacman pkgs: 1406 libs: 396
tools: pamac,paru Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.28
System install date: 2021-09-03
Last full system update: 2023-07-25 ↻
Relevant software: timeshift NetworkManager mkinitcpio
btw. I did a reboot sec ago and before this inxi output
thank you for supporting!
greetings
