Hey guys, my brothers terminal looks wrong and barely a prompt, wasn’t sure if it’s a config thing that could be deleted or if it’s something I can copy out of my own machine for him, he’s not a tinkerer so not sure how it got killed, he said he wasn’t playing with anything prior, which I believe as he’s REALLY not a tinkerer.
This is what it’s opening up like
This is his inxi
❯ garuda-inxi
Kernel: 6.13.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=9c4dae6f-81a1-45f5-9a00-b543c912a910 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.0 tk: Qt v: N/A info: frameworks v: 6.10.0
Type: Laptop System: Dell product: Latitude 7490 v: N/A
Mobo: Dell model: 0KP0FT v: A00 serial: <superuser required> part-nu: 081C
uuid: <superuser required> UEFI: Dell v: 1.37.0 date: 01/29/2024
ID-1: BAT0 charge: 56.1 Wh (100.0%) condition: 56.1/60.0 Wh (93.5%)
volts: 8.3 min: 7.6 model: Samsung SDI DELL V49408A type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-8650U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF6
Speed (MHz): avg: 800 min/max: 400/4200 scaling: driver: intel_pstate
8: 800 bogomips: 33599
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
chip-ID: 1bcf:2b96 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
Monitor-1: eDP-1 model: BOE Display 0x06ee built: 2016 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1920x1080
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) device-ID: 8086:5917 memory: 3.72 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (KBL GT2) driver: N/A device-ID: 8086:5917
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
API: ALSA v: k6.13.2-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 238.47 GiB used: 70.48 GiB (29.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKKF256G8 SATA 256GB
tech: SSD serial: <filter> fw-rev: D04N scheme: GPT
used: 70.48 GiB (29.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.63 GiB used: 162.6 MiB (2.1%)
max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 49.0 C pch: 39.5 C mobo: N/A
Memory: total: 8 GiB available: 7.63 GiB used: 4.78 GiB (62.6%)
Processes: 268 Power: uptime: 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1562 libs: 437 tools: octopi,paru pm: appimage
pkgs: 0 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
Garuda (2.6.26-1.1):
System install date: 2024-04-19
Last full system update: 2025-02-15 ↻
