Terminal Autocomplete in Garuda Dragonized
Hi guys, i'm still pretty new to linux and i still cant figure out what the terminal in garuda is using to have that autocomplte suggestion?
What terminal do you use and where is your inxi -Faz?
uhh idk about the Inxi-Faz but ive switche to bash and im using yakuake
It is in the template you just delete.
Hello.
inxi -Faz
Got it, brb im just gonna install inxi first
It is installed BTW
I should have included in the question first that im trying to implement on my kali machine what i like about my garuda machine, but idk how to do some of those changes and this is one of them but this is my inxi -Faz
System:    Kernel: 5.10.0-kali9-amd64 x86_64 bits: 64 compiler: gcc v: 10.2.1
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.10.0-kali9-amd64 root=UUID=0f44fd2d-d4fa-4537-96a5-6c01f2057255 ro quiet
           splash
           Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.26.0
           Distro: Kali GNU/Linux 2021.3 base: Debian testing
Machine:   Type: Vmware System: VMware product: VMware Virtual Platform v: N/A serial: <filter> Chassis: No Enclosure type: 1
           Mobo: Intel model: 440BX Desktop Reference Platform serial: <filter> BIOS: Phoenix v: 6.00 date: 07/22/2020
Battery:   ID-1: BAT1 charge: 28.1 Wh (100.0%) condition: 28.1/48.9 Wh (57.5%) volts: 16.1 min: N/A
           model: VMware Virtual Battery type: Unknown serial: N/A status: Unknown
CPU:       Info: 4x Single Core model: Intel Core i5-8300H bits: 64 type: SMP arch: Kaby Lake note: check family: 6
           model-id: 9E (158) stepping: A (10) microcode: FFFFFFFF cache: L2: 32 MiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 18432
           Speed: 2304 MHz min/max: N/A Core speeds (MHz): 1: 2304 2: 2304 3: 2304 4: 2304
           Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT Host state unknown
           Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Graphics:  Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.18.0.0 bus-ID: 00:0f.0 chip-ID: 15ad:0405 class-ID: 0300
           Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver: loaded: vmware
           unloaded: fbdev,modesetting,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3") s-diag: 583mm (23")
           Monitor-1: Virtual1 res: 1920x1080 hz: 60
           OpenGL: renderer: llvmpipe (LLVM 11.0.1 256 bits) v: 4.5 Mesa 20.3.5 compat-v: 3.1 direct render: Yes
Audio:     Device-1: Ensoniq ES1371/ES1373 / Creative Labs CT2518 driver: snd_ens1371 v: kernel bus-ID: 02:02.0
           chip-ID: 1274:1371 class-ID: 0401
           Sound Server-1: ALSA v: k5.10.0-kali9-amd64 running: yes
           Sound Server-2: PulseAudio v: 14.2 running: yes
           Sound Server-3: PipeWire v: 0.3.38 running: yes
Network:   Device-1: Intel 82371AB/EB/MB PIIX4 ACPI vendor: VMware Virtual Machine type: network bridge driver: N/A
           modules: i2c_piix4 port: 1060 bus-ID: 00:07.3 chip-ID: 8086:7113 class-ID: 0680
           Device-2: Intel 82545EM Gigabit Ethernet vendor: VMware PRO/1000 MT Single Port driver: e1000 v: kernel port: 2000
           bus-ID: 02:01.0 chip-ID: 8086:100f class-ID: 0200
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 80 GiB used: 15.32 GiB (19.1%)
           ID-1: /dev/sda maj-min: 8:0 vendor: VMware model: Virtual S size: 80 GiB block-size: physical: 512 B logical: 512 B
           type: N/A serial: N/A rev: 1.0 scheme: MBR
Partition: ID-1: / raw-size: 79.04 GiB size: 77.25 GiB (97.73%) used: 15.32 GiB (19.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
Swap:      Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 975 MiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda5 maj-min: 8:5
Sensors:   Message: No sensor data found. Is lm-sensors configured?
Info:      Processes: 235 Uptime: 54m wakeups: 1628 Memory: 3.83 GiB used: 1.8 GiB (47.0%) Init: systemd v: 249 runlevel: 5
           tool: systemctl Compilers: gcc: 10.2.1 alt: 10 clang: 11.0.1-2 Packages: apt: 2436 lib: 1100 Shell: Bash v: 5.1.8
           running-in: yakuake inxi: 3.3.06
If you include terminal outputs in your post please use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
Edit your post, please.
IDK kali. Sorry.
I understand but on the case that it isnt kali or debian based, how do i customize the autocomplete in the terminal?
Use fish.e.g.
There are specific support routes for Kali. It is Debian-based so anything implemented on Garuda (being Arch-based) may not directly apply. Therefore, the question of
would be better asked of the Kali community.
Or use zsh, which can have autocompletion, and, if I remember correctly, was a standard in Kali a couple of years ago (the last time I saw it)
