When I open terminal applications such as vi and ncspot they default to xterm instead of kitty. Is there any way to change this globally without uninstalling the terminal applications or modifying all of the .desktop files individually?
You haven’t provided your garuda-inxi according to template. Please always follow the template when requesting help.
Now assuming you are using i3wm, given the topic i3wm
Following this wiki link.
By default when pressing
$mod+Enter
it launches thei3-sensible-terminal
which is a script that invokes a terminal. See i3-sensible-terminal(1) for the order terminals are invoked in.To instead launch a terminal of choice, modify this line in
~/.config/i3/config
bindsym $mod+Return exec i3-sensible-terminal
Alternatively, set the
$TERMINAL
environment variable.
So I believe appending
TERMINAL=kitty
to the /etc/environment
file should be enough. You would have to relogin though for the environment variable to take effect.
