Kernel: 6.2.1-273-tkg-bmq arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: intel_pstate=passive split_lock_detect=off intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux-linux-tkg-bmq-generic_v3
root=UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d rw [email protected]
sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog
nmi_watchdog=0 [email protected]\boot\initramfs-linux-tkg-bmq-generic_v3.img
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
UEFI: American Megatrends v: P5.10 date: 10/20/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3897 high: 4625 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4223 2: 3700
3: 4625 4: 3697 5: 3698 6: 4625 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700
12: 3700 bogomips: 88890
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,HDMI-A-1,HDMI-A-2 empty: DP-2
bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
gpu: amdgpu d-rect: 5120x1728 display-ID: 0
Monitor-1: DP-1 pos: bottom-r res: 2048x864 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: top-center res: 1536x864 size: N/A modes: N/A
Monitor-3: HDMI-A-2 pos: primary,top-left res: 1536x864 size: N/A
modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.49 6.2.1-273-tkg-bmq) direct-render: Yes
bus-ID: 1-1.3:13 gen: 4 chip-ID: 054c:0cd3 speed: 16 GT/s class-ID: 0300
lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sony WH-1000XM3 [Wireless Noise-Canceling Headphones] type: USB
driver: hid-generic,usbhid
Device-4: Sony INZONE H9 / H7 type: USB
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid bus-ID: 3-4.1:4
chip-ID: 054c:0e53 class-ID: 0a00
Sound API: ALSA v: k6.2.1-273-tkg-bmq running: yes
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: hid-generic,usbhid bus-ID: 1-1.3:13 chip-ID: 054c:0cd3
Device-1: Edimax Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 3-2:2 chip-ID: 7392:c611 class-ID: e001 serial: <filter>
Local Storage: total: 2.96 TiB used: 4.13 TiB (139.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 3B4QFXO7 temp: 42.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
used: 779.68 GiB (83.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
used: 24.6 MiB (8.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
ID-1: swap-1 type: zram size: 31.26 GiB used: 3.79 GiB (12.1%)
System Temperatures: cpu: 64.5 C mobo: 37.0 C gpu: amdgpu temp: 56.0 C
mem: 60.0 C
Fan Speeds (RPM): cpu: 2023 fan-1: 0 fan-3: 1327 fan-4: 1485 fan-5: 1221
gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.14 vbat: 3.28 gpu: amdgpu watts: 29.00
Processes: 507 Uptime: 34m wakeups: 4 Memory: 31.26 GiB
used: 11.74 GiB (37.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 2504
pm: pacman pkgs: 2481 libs: 584 tools: octopi,paru pm: appimage pkgs: 0
pm: flatpak pkgs: 23 Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-13
Last full system update: 2023-03-01 ↻
Failed units: systemd-networkd-wait-online.service systemd-oomd.socket
telegram no longer opens giving the following message when ran from a terminal
telegram-desktop: error while loading shared libraries: libvpx.so.7: cannot open shared object file: No such file or directory
