Tecknet UsbC / A Adapter is disconnecting and reconnecting; after using Beatport & Mammoth Interactive Courses for about 10 hours on Brave Browser; only happening on one machine.
Happening for everything now even when the browser is not open.
Guessing some sort of cache poisoning exploit because running Bleechbit seems to stop it from happening when Brave is not open at least. (chrome is exploitable)
Much Appreciated.
Kernel: 6.9.7-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 14.1.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=8ce260fd-1bad-4769-927f-1b285b84e21b rw rootflags=subvol=@
quiet rd.luks.uuid=fea446ef-393c-4abf-8798-e0ed260636ee loglevel=3
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: ASUSTeK product: ZenBook UX425UG_Q408UG v: 1.0
Mobo: ASUSTeK model: UX425UG v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: UX425UG.301
date: 12/05/2021
ID-1: BATT charge: 21.9 Wh (56.0%) condition: 39.1/63.1 Wh (61.9%)
volts: 12.0 min: 12.0 model: ASUSTeK UX425 type: Li-ion serial: <filter>
status: discharging cycles: 124
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 905 high: 1461 min/max: 400/4056 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1461 2: 1430 3: 1397
4: 400 5: 400 6: 400 7: 1397 8: 400 9: 1397 10: 400 11: 1388 12: 400
bogomips: 50327
Device-1: NVIDIA TU117M [GeForce MX450] vendor: ASUSTeK driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 02:00.0
chip-ID: 10de:1f9c class-ID: 0302
Device-2: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 43.0 C
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.2-arch1.1
renoir LLVM 17.0.6 DRM 3.57 6.9.7-hardened1-1-hardened)
device-ID: 1002:164c memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.2-arch1.1
device-ID: 1002:164c surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce MX450 driver: nvidia v: 555.58.02
device-ID: 10de:1f9c surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.9.7-hardened1-1-hardened status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
Message: No PCI device data found.
Device-1: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.1:3
IF: enp4s0f3u1u1 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 18.66 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 38.9 C
ID-1: / raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
used: 18.63 GiB (19.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-fea446ef-393c-4abf-8798-e0ed260636ee
used: 26.3 MiB (27.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
ID-4: /var/log raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.17 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.2 C mobo: N/A gpu: amdgpu temp: 44.0 C
Memory: total: 8 GiB note: est. available: 7.17 GiB used: 3.73 GiB (52.0%)
Processes: 337 Power: uptime: 32m states: freeze,mem suspend: s2idle
wakeups: 0 services: org_kde_powerdevil, power-profiles-daemon, upowerd
Packages: pm: pacman pkgs: 1390 libs: 388 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date: 2024-06-26
Last full system update: 2024-07-03
Failed units: nmb.service
