TeamSpeak3 steals my OS audio?
Hi, guys!
I'm having a pretty weird things going on after I switched to pipewire from pulseaudio.
So I'm uninstalled pulseaudio, installed pipewire, ALSA is also installed.
After a reboot I noticed that when I'm using TeamSpeak3 for Linux - I have literally no sound in system. When I try to open a YouTube video - it just stalls, cause it have literally no sound. No sound in audio or video players. Also OBS is not recording a desktop audio or microphone (as I see - equalizer is just dead). As soon as I close TeamSpeak3 - sound returns, all working as intended.
What is the possible issue I can solve to make all my setup work?
Here is my system info:
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=9dbc2d80-f8ff-4292-9f96-dc64de48b51f rw rootflags=subvol=@
resume=UUID=a34c3215-eb63-4d11-b6c9-b05946c5521a loglevel=3 ibt=off
Type: Laptop System: Micro-Star product: GS65 Stealth Thin 8RF v: REV:1.0
Mobo: Micro-Star model: MS-16Q2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16Q2IMS.112 date: 05/21/2019
ID-1: BAT1 charge: 76.7 Wh (95.5%) condition: 80.3/80.3 Wh (100.0%)
volts: 16.7 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 3691 high: 4002 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4000 2: 2200 3: 4002
4: 4002 5: 3998 6: 4001 7: 4000 8: 4002 9: 3998 10: 4000 11: 3900
12: 2200 bogomips: 52799
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP104M [GeForce GTX 1070 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-2,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:1ba1 class-ID: 0300
Monitor-1: eDP-1 mapped: eDP-1-1 model: AU Optronics 0x80ed built: 2017
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
OpenGL: renderer: NVIDIA GeForce GTX 1070 with Max-Q Design/PCIe/SSE2
v: 4.6.0 NVIDIA 515.76 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 1-2:2 chip-ID: 0c76:161f
class-ID: 0300 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
Device-3: JMTek LLC. USB PnP Audio Device type: USB
Sound API: ALSA v: k5.19.13-zen1-1-zen running: yes
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 953.88 GiB used: 436.3 GiB (45.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: RBUSNS8180S3512GJ
type: SSD serial: <filter> rev: 61D1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Transcend
model: TS512GSSD230S size: 476.94 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 02J0 scheme: GPT
ID-1: / raw-size: 467.46 GiB size: 467.46 GiB (100.00%) used: 436.3 GiB
(93.3%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-2: /boot/efi raw-size: 701 MiB size: 699.6 MiB (99.80%) used: 308 KiB
(0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 467.46 GiB size: 467.46 GiB (100.00%) used: 436.3
GiB (93.3%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-4: /var/log raw-size: 467.46 GiB size: 467.46 GiB (100.00%) used: 436.3
ID-5: /var/tmp raw-size: 467.46 GiB size: 467.46 GiB (100.00%) used: 436.3
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 58.0 C pch: 55.0 C mobo: N/A gpu: nvidia
temp: 55 C
Processes: 329 Uptime: 13m wakeups: 1 Memory: 15.47 GiB used: 2.84 GiB
(18.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1983
libs: 559 tools: aura,octopi,paru Shell: fish v: 3.5.1 running-in: konsole
inxi: 3.3.22
Garuda (2.6.8-1):
System install date:     2022-05-26
Last full system update: 2022-10-10
Update.
Also all my directories in /etc/pipewire/ are empty, no config files, nothing:
╭─rat@SSDDgl in /etc/pipewire🔒 as 🧙
╰─λ ls
drwxr-xr-x - root 25 апр 23:55  client-rt.conf.d
drwxr-xr-x - root 25 апр 23:55  client.conf.d
drwxr-xr-x - root 25 апр 23:55  jack.conf.d
drwxr-xr-x - root 25 апр 23:55  minimal.conf.d
drwxr-xr-x - root  9 окт 00:27  pipewire-pulse.conf.d
drwxr-xr-x - root 25 апр 23:55  pipewire.conf.d
So I can't use this solution: PipeWire - ArchWiki
These directories exist not because they are supposed to be full of stuff, but rather they are meant to be a place to store config files where PipeWire will find them and respect the settings they prescribe. Unless you, your Linux distribution, or some software you install on your machine puts something inside these directories it is normal for them to be empty.
To try the intervention you found in ArchWiki, just make the file first:
micro /etc/pipewire/media-session.d/alsa-monitor.conf
Add the line needed:
api.alsa.headroom = 1024
Ctrl+q to exit out of micro, make sure to save the file.
:point_up: Note: that intervention is specifically for systems running pipewire-media-session; if you are running WirePlumber, there is a separate set of instructions below that you should follow instead.
@BluishHumility thanks for reply.
Created the directory and config file as mentioned in ArchWiki, rebooted - unfortunately it didn't help.
Launched TeamSpeak after reboot - and I don't have sound in the whole system.
Closing TeamSpeak - the sound appears again.
In case with OBS its like vise versa: if I open TS before OBS - I don't have sound in OBS and the whole system. With the option of starting OBS first, the sound in the entire system does not disappear, but I'm getting this error in TeamSpeak:
It seems that the OBS reserves the devices I use for itself and same for TeamSpeak.
Update:
I also have a wine version of TeamSpeak installed and it works perfectly with OBS and OS, but I'm really interested to make the native Linux TeamSpeak client to work because wine version is pretty laggy.
Can you boot a snapshot that is at least 7 days old? I also had a similar problem (as soon as I start Apex Legends all sound is gone) and using older version fixed it for me.
@mrvictory I know that it will probably fix the problem, but I want to fix it with my current state of system (with all installed updates).
I also just installed flatpak version of TeamSpeak and it works as intended.
Still I want to solve the following issue and get Arch version of TS to work. :thinking:
Also I'm pretty sure that this is not a TS fault, because Arch version was updated 2021-10-13 last time.
So maybe one of the system updates broke the TS?
I wasn't clear. I meant that not an older version of an application but older version of pipewire fixed it for me.
Ah, yes, now I see what do you mean. But unfortunately I don’t have older version of pipewire, because it was my first time installation, so I don’t have older version in my package cache. :upside_down_face:
My snapahots got auto deleted :man_facepalming:, I will investigate later when I have time. Meanwhile you can check out downgrade.
The commands below has sort-of brought back audio for me, I have to disable/enable sound or change sound level but it works. Reboot after running these.
sudo pacman -Rdd pipewire-audio
sudo pacman -U https://archive.archlinux.org/packages/l/lib32-pipewire/lib32-pipewire-1:0.3.58-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/l/lib32-pipewire-jack/lib32-pipewire-jack-1:0.3.58-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/p/pipewire/pipewire-1:0.3.58-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/p/pipewire-alsa/pipewire-alsa-1:0.3.58-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/p/pipewire-jack/pipewire-jack-1:0.3.58-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/p/pipewire-v4l2/pipewire-v4l2-1:0.3.58-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/p/pipewire-zeroconf/pipewire-zeroconf-1:0.3.58-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/w/wireplumber/wireplumber-0.4.11-4-x86_64.pkg.tar.zst
mrvictory Will definitely try this. Thank you!
