Taskbar mic control showing opposite toast of what it should
Whenever I toggle my mic control, it shows the opposite toast notification of what it should.
Garuda-inxi: System:Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 - Pastebin.com
Please, post the garuda-inxi in the forum.
Only log files longer 32000 chars are fine in PrivateBin
root=UUID=84c2d676-7cb0-47ef-a50a-f71fbbc1a646 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 2.30
date: 08/31/2020
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4153 high: 4175 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4168 2: 4173
3: 4175 4: 4064 5: 4164 6: 4132 7: 4160 8: 4160 9: 4167 10: 4151 11: 4170
12: 4155 bogomips: 86403
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1
bus-ID: 2b:00.0 chip-ID: 10de:2484 class-ID: 0300
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DP-2 mapped: DP-3 note: disabled pos: primary,right
model: Samsung LF24T35 serial: <filter> built: 2021 res: 1920x1080 dpi: 92
gamma: 1.2 size: 528x297mm (20.79x11.69") diag: 606mm (23.9") ratio: 16:9
Monitor-2: HDMI-A-2 mapped: HDMI-1 note: disabled pos: left
model: Dell SE2417HG serial: <filter> built: 2019 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 545.29.06
device-ID: 10de:2484 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
bus-ID: 2b:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 5
lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 1038:1250 class-ID: 0300
Device-4: HP HyperX SoloCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 03f0:078b class-ID: 0300
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
IF: enp42s0 state: down mac: <filter>
Device-3: TP-Link 802.11ac NIC driver: rtl88x2bu type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 2357:0138
IF: wlp2s0f0u6 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
Local Storage: total: 1.14 TiB used: 108.4 GiB (9.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kikwot model: FS810 250GB
tech: SSD serial: <filter> fw-rev: A25D scheme: GPT
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD
used: 108.4 GiB (46.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 64.2 C mobo: N/A gpu: nvidia temp: 43 C
Processes: 389 Uptime: 44m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 6.42 GiB (20.5%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1873
pm: pacman pkgs: 1858 libs: 534 tools: octopi,pamac,paru pm: flatpak
pkgs: 15 Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-17
Last full system update: 2023-11-26
but do you have a solution?
Believe me, I would have posted it.
so, there’s no way to fix it?
Same like Siemens cellphones and others?
You see what you can activate?
So, you posted 37 minutes ago, on a Sunday evening, when do you think a solution has to be submitted by us for an app that we haven’t programmed?
Just search the web, search the developer of the app and open issue on his gitlab, github or web side.
it’s part of the os
Can you be more specific? What does if exactly say?
What is your method for toggling the device?
there is a little mic in the taskbar next to my wifi icon when a game is using my mic, I have tried using that to toggle, but when it shows no red line on it, the toast that it gives says muted, but when there is a red line across it, the toast notification says unmuted
Are there any BIOS updates newer than 2020?
Good catch! There seems to have been many BIOS updates. @Steamrex25 should upgrade to the latest BIOS regardless because there has been much security improvements and the like.
https://www.msi.com/Motherboard/B550M-PRO-VDH-WIFI/support
Please note that if you update to the latest BIOS, it looks like it might reset the Secure Boot setting so make sure that is still off.
