To be honest, I'm new so my belief can be wrong, but I think it's just animation and it don't need output. Although walk through now looks like simple switch through (the simple alternative animation) if you know what I mean. In case I can provide some logs I'm not aware about, I will provide them as you instruct me
What I tried to solve issues?
it happened after some installations, like lollypop, mpv, flatpak, so I tried removing them by sudo pacman -R packageName. But no help. I installed them again leaving flatpak alone as I saw flatpak is considered unsupported.
Restoration of old snapshots.
What I think I should possibly try?
Reinstalling n configuring plasma kde, sadly I'm still clueless about it, specially reconfiguration
System info:
Laptop: Acer Nitro 5 AN515-44 (2021), 512gb ssd, 8gb ram ddr4
Graphics: GTX 1650, 4gb
Os: Multiboot - Win 11 21H2, Garuda Dr4gonized (kept up to date, installed 3 days ago, my 1st ever linux)
If details given here insufficient, please guide me, I will get you required details
Edit: I just found that inxi is a command, I will post out results soon as am not on laptop at moment. Sorry for inconvenience
I am not sure exactly what you are referring to but a couple of the task switching animations were removed from the latest version of plasma by the kde developers. If you were using one of those that could explain the change.
Ohh
Thanks for info
I will look into it and respond soon
Btw I am referring to the default one when you fresh install garuda (I mean I did 3 days ago, and that was the animation I saw, so I call it default), where active tasks scroll with window to be selected is flat while rest are tilted
Sorry for a blurry image, I clicked that in bit of hurry earlier.
Still not clear to me what the problem is.
Anyway, you could give a look at Settings -> Window Management -> Task switcher, especially the visualization drop-down field, if you find any settings that it's worth trying changing.
For animation problems in general, not related only to the task switcher, you could give a look at the "compositor".
Sometimes when you open its settings there's a message saying that it crashed and offering to reset it. Also there you'll find settings to play with. Take notes of what you change...
Could it be that the task switcher animation you remember was the initial one (I mean, the one when you installed, before the first full update) ?
In that case, maybe this could be as @dalto suggested, several animations were removed in the recent plasma upgrade (and there's nothing we can do about it).
Final update
I did try fresh install again
and after full update
KDE removed "Cover Switch" Task Switcher theme, i.e. so called default task switcher theme in garuda.
