I cannot seem to find out how to circumvent this error in journal.
Any help is appreciated
journalctl -p 3 -xb
okt. 27 22:42:51 spectre systemd-udevd[299]: nvme0: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1d.0/0000:3d:00.0/nvme/nvme0/queue/scheduler}, ignoring: No such file or directory
okt. 27 22:42:51 spectre systemd-udevd[297]: nvme0n1p2: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1d.0/0000:3d:00.0/nvme/nvme0/nvme0n1/nvme0n1p2/queue/scheduler}, ignoring: No such file or directory
okt. 27 22:42:51 spectre systemd-udevd[295]: nvme0n1p1: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1d.0/0000:3d:00.0/nvme/nvme0/nvme0n1/nvme0n1p1/queue/scheduler}, ignoring: No such file or directory
okt. 27 22:42:52 spectre systemd-udevd[317]: nvme0n1p1: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1d.0/0000:3d:00.0/nvme/nvme0/nvme0n1/nvme0n1p1/queue/scheduler}, ignoring: No such file or directory
okt. 27 22:42:52 spectre systemd-udevd[312]: could not read from '/sys/module/acpi_cpufreq/initstate': No such device
❯ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
zram0 254:0 0 496,4M 0 disk [SWAP]
zram1 254:1 0 496,4M 0 disk [SWAP]
zram2 254:2 0 496,4M 0 disk [SWAP]
zram3 254:3 0 496,4M 0 disk [SWAP]
zram4 254:4 0 496,4M 0 disk [SWAP]
zram5 254:5 0 496,4M 0 disk [SWAP]
zram6 254:6 0 496,4M 0 disk [SWAP]
zram7 254:7 0 496,4M 0 disk [SWAP]
nvme0n1 259:0 0 476,9G 0 disk
├─nvme0n1p1 259:1 0 300M 0 part /boot/efi
└─nvme0n1p2 259:2 0 476,6G 0 part /run/timeshift/backup
❯ inxi -Fxxxza
System: Kernel: 5.9.1-zen2-1-zen x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=8344326d-e1fe-46c6-bf83-b03108b13786 rw
rootflags=subvol=@ quiet splash loglevel=3 mitigations=off sysrq_always_enabled=1
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Convertible System: HP product: HP Spectre x360 Convertible 15-ch0xx v: N/A serial: <filter> Chassis:
type: 31 serial: <filter>
Mobo: HP model: 83BA v: 57.33 serial: <filter> UEFI: AMI v: F.30 date: 03/07/2019
Battery: ID-1: BAT0 charge: 56.4 Wh condition: 78.3/78.3 Wh (100%) volts: 11.8/11.6 model: HP Primary type: Li-ion
serial: N/A status: Discharging
Device-1: hid-0018:04F3:25BF.0001-battery model: ELAN2514:00 04F3:25BF serial: N/A charge: N/A status: N/A
CPU: Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 8E (142)
stepping: A (10) microcode: D6 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31999
Speed: 3668 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 1944 2: 3444 3: 3391 4: 3365 5: 2503 6: 3632 7: 3424
8: 3489
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and usercopy barriers only; no swapgs barriers
Type: srbds status: Vulnerable
Graphics: Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Hewlett-Packard driver: nvidia v: 455.28
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1d10
Device-3: Quanta HP Wide Vision FHD Camera type: USB driver: uvcvideo bus ID: 1-5:2 chip ID: 0408:5251
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 192 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 3840x2160 hz: 60 dpi: 283 size: 345x194mm (13.6x7.6") diag: 396mm (15.6")
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.1-zen2-1-zen
Network: Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: e000 bus ID: 3b:00.0 chip ID: 8086:2526
Device-2: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb bus ID: 1-7:3 chip ID: 8087:0025
Drives: Local Storage: total: 476.94 GiB used: 283.17 GiB (59.4%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 476.94 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: AAHA4102 scheme: GPT
Partition: ID-1: / raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 283.17 GiB (59.4%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /home raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 283.17 GiB (59.4%) fs: btrfs dev: /dev/nvme0n1p2
ID-3: /var/log raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 283.17 GiB (59.4%) fs: btrfs
dev: /dev/nvme0n1p2
ID-1: swap-1 type: zram size: 496.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 496.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 496.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 496.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 496.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 496.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 496.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 496.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 49.0 C mobo: N/A
Info: Processes: 268 Uptime: 34m Memory: 15.51 GiB used: 2.44 GiB (15.7%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1297 lib: 307 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.06
