Just updated my system, and after rebooting whenever I login I get the Qtile bar at the bottom of the screen (was at the top), but what looks like the login manager doesn’t go away until I use to spawn a program. My default Garuda wallpaper doesn’t show up, and the login won’t disappear until I spawn a terminal. While I can see the workspaces numbered, they aren’t sorted by the Greek letters (it’s all Arabic numerals as usual) any longer. As a result, I can’t click on the Garuda logo on the bar to launch jgmenu either. I did install litecli-git from the AUR after doing the system update (and before rebooting). I don’t THINK that should’ve caused this, but just including it for full disclosure. I can boot into an old snapshot, and everything works like normal. I’m just trying to figure out what/how everything got messed up. There was a snapshot mentioning some things about adwaita (not sure why since I’m not running Gnome), but I did not explicitly upgrade that and build a snapshot. So that was must’ve been done by the system upgrade.
Kernel: 6.9.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=c70eb515-37ec-4022-a15b-471e53b86e63 rw rootflags=subvol=@
quiet resume=UUID=d1fd6920-972d-40c8-90de-eb9e5b5e7602 loglevel=3
amdgpu.ppfeaturemask=0xffffffff ibt=off
Desktop: Qtile v: 0.26.1.dev0+ge4b4bb8b.d20240523 tools:
avail: i3lock,lxlock,xautolock vt: 2 dm: SDDM Distro: Garuda
Type: Desktop Mobo: ASRock model: B650E PG Riptide WiFi
Megatrends LLC. v: 1.30.AS02 date: 09/28/2023
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 1342 high: 4836 min/max: 400/5050 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 4836
4: 4831 5: 400 6: 3302 7: 400 8: 400 9: 400 10: 3704 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 134147
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire PULSE driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2, HDMI-A-1, HDMI-A-2, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-3, DP-4, DP-5, HDMI-A-3, Writeback-2
bus-ID: 11:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 32.0 C
Display: x11 server: X.Org v: 21.1.13 compositor: Qtile
v: 0.26.1.dev0+ge4b4bb8b.d20240523 driver: X: loaded: amdgpu
s-diag: 1165mm (45.88")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Acer XV273K serial: <filter>
built: 2021 res: 3840x2160 hz: 120 dpi: 163 gamma: 1.2
max: 3840x2160 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.0-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.9.2-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.0-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 24.1.0-arch1.1 device-ID: 1002:164e surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.1.0-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.6
Device-4: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 2972:0047 class-ID: fe01
API: ALSA v: k6.9.2-zen1-1-zen status: kernel-api
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0c:00.0 chip-ID: 14c3:0608
IF: wlp12s0 state: up mac: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0d:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp13s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0e8d:0608
Local Storage: total: 1.86 TiB used: 803.85 GiB (42.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: solidgm model: SSDPFKKW020X7
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 001C temp: 39.9 C scheme: GPT
ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 803.85 GiB (42.9%)
ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
used: 803.85 GiB (42.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-1: swap-1 type: zram size: 30.47 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 33.52 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 39.5 C mobo: 32.0 C
GPU: device: amdgpu temp: 45.0 C mem: 50.0 C fan: 2 watts: 24.00
device: amdgpu temp: 32.0 C
Memory: total: 32 GiB note: est. available: 30.47 GiB used: 2.65 GiB (8.7%)
Processes: 305 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.18 GiB Init: systemd v: 255
Packages: pm: pacman pkgs: 1441 libs: 444 tools: paru pm: flatpak pkgs: 0
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: kitty inxi: 3.3.34
System install date: 2023-11-22
Last full system update: 2024-05-30
