I am using Garuda Linux KDE Dragonized version. After a system update (pacman -Syyu):
- There is a black box around latte-dock
- Animations have been disabled
- Window manager (alt-tab) shows an ugly looking list instead of the animated scroll
- There is screen tearing in almost all the applications while scrolling (Browser, Slack, etc)
Versions:
kernel linux-lts 5.4.98-1
garuda-dr460nized r150.8c52f91-1
latte-dock-git r5016.c922aec8-1
Likely the compositor has crashed or has otherwise been disabled. Reenable it.
If that doesn't work then post full details about your system (inxi -Fxxxz) and the packages you just updated (from /var/log/pacman.log).
Hi thank you for your answer
Re-enabling the compositor has fixed the issue, thanks!
zoner
4
Welcome to the Garuda Forum. Enjoy.
gary
I had the same issue after update yesterday and re-enabling the compositor also fixed the issue for me.
system
Closed
6
