╭─drago@gnulinux in ~
╰─λ inxi -Faz
Kernel: 5.15.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=64706a94-d627-47bc-a2a5-c10e058ff518 rw rootflags=subvol=@
resume=UUID=13a9e0f7-0f67-4bdf-a746-27eb5d0b4182 loglevel=3
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3103
date: 06/17/2020
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3718 high: 4299 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3371 2: 3906
3: 3606 4: 3490 5: 3680 6: 3767 7: 3966 8: 3611 9: 3518 10: 4299 11: 4201
12: 3628 13: 3750 14: 3601 15: 3538 16: 3569 bogomips: 115202
vendor: Gigabyte driver: amdgpu v: kernel bus-ID: 0a:00.0
chip-ID: 1002:731f class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: HDMI-A-0 res: 1920x1080 dpi: 92 size: 532x304mm (20.9x12.0")
diag: 613mm (24.1")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.42.0
5.15.8-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.1 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 0a:00.1 chip-ID: 1002:ab38 class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
Device-3: Realtek Realtek Audio USB type: USB driver: snd-usb-audio
bus-ID: 1-6:3 chip-ID: 0bda:4938 class-ID: 0102 serial: <filter>
Sound Server-1: ALSA v: k5.15.8-zen1-1-zen running: yes
port: e000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
Local Storage: total: 931.51 GiB used: 663.96 GiB (71.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD G5 BICS4
type: SSD serial: <filter> rev: 00WD scheme: GPT
ID-1: / raw-size: 896.85 GiB size: 896.85 GiB (100.00%)
used: 663.96 GiB (74.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 896.85 GiB size: 896.85 GiB (100.00%)
ID-4: /var/log raw-size: 896.85 GiB size: 896.85 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.85 GiB size: 896.85 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.33 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 59.0 C
mem: 62.0 C
Processes: 440 Uptime: 17m wakeups: 0 Memory: 31.34 GiB
used: 7.87 GiB (25.1%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1847 lib: 523 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.10
╭─drago@gnulinux in ~ took 1s
╰─λ
so i booted into my pc today and everything was fine until discord crashed when opening which has become a frequent thing but that's not what my problem is,
my problem is that the toolbar/application tray is not appearing neither does pressing the super user key, i tried restarting multiple times and tried the fallback kernel then i tried "pacman -Syuu" i it updated and restarted it but nothing happened
im at a loss i don't know how to fix this
