Hey everyone, I usually don't post since I often find my answers when reading through forums, but unfortunately this one has me stumped a little as I'm not quite sure how to find my answer.
Up until a couple of days ago my system was running perfectly fine, but after updating my system it has taken a massive hit to performance. For example, System Shock Remake used to be at a good 140fps but now plummets to as low as 20fps when I boot it, Apex Legends runs below 60 and even GZDoom has started getting some stutters too.
I've ran through the usual troubleshooting issues like changing kernel, setting BIOS to default and other things like that but they unfortunately didn't solve the problem. I pondered it might be a bad Mesa driver causing problems but I also remember a video by The Linux Experiment and how he mentioned that AMD GPUs can sometimes roll back into a low power mode for no discernible reason, which seems likely since my GPU was still running at 99% utilisation even with the terrible performance, no temperature issues to report neither as my system's components sits comfortably between 50 to 70 celsius.
The issue is I'm not quite sure how to go about fixing this or what to tweak in order to solve the problem, as there was no documentation about the problem linked in said video, so I find myself getting confused when researching. I'm sure this is an easy enough fix and I'm probably just looking in the wrong places or missing something obvious but any pointers on the problem would be greatly appreciated.
Kernel: 6.4.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c87e17cf-c2aa-4cb7-9b3f-535b1b50e245 rw rootflags=subvol=@
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop System: Tactus product: Custom v: N/A
Mobo: ASUSTeK model: ROG STRIX X570-E GAMING WIFI II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4101
date: 09/10/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA201204
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2623 high: 3900 min/max: 2200/5218 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3899
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 3892 14: 2200 15: 2200 16: 3892 17: 3893 18: 2200 19: 3900
20: 2200 21: 2200 22: 2200 23: 2200 24: 3893 bogomips: 186851
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Gigabyte
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 0c:00.0 chip-ID: 1002:73bf
Device-2: Valve 3D Camera driver: uvcvideo type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-2.1:3 chip-ID: 28de:2400
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: Gigabyte AORUS FI32Q serial: <filter> built: 2021
res: 2560x1440 dpi: 93 gamma: 1.2 size: 698x392mm (27.48x15.43")
diag: 801mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 15.0.7 DRM 3.52 6.4.9-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Creative Pebble V3 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
chip-ID: 041e:3272 class-ID: 0300 serial: <filter>
Device-4: RODE Microphones NT-USB driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
chip-ID: 19f7:0003 class-ID: 0300
Device-5: Valve VR Radio driver: cdc_acm,hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.3.2:7
chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
Device-6: Valve VR Radio & HMD Mic
lanes: 1 mode: 1.1 bus-ID: 5-2.3.3:8 chip-ID: 28de:2102 class-ID: 0102
API: ALSA v: k6.4.9-zen1-1-zen status: kernel-api with: aoss
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-4: ASUSTek ROG KERIS WIRELESS driver: hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.4:5
chip-ID: 0b05:1960 class-ID: 0301
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:6 chip-ID: 0e8d:0608
Local Storage: total: 8.19 TiB used: 4.99 TiB (60.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: FireCuda 530
ZP1000GM30013 size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU6SM001
temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
tech: SSD serial: <filter> fw-rev: 2B6Q
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000NE001-2MA101
tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01
used: 53.53 GiB (5.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: 39.0 C gpu: amdgpu temp: 54.0 C
mem: 54.0 C
Processes: 564 Uptime: 9m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.7 GiB used: 5.11 GiB (8.1%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1364
pm: pacman pkgs: 1356 libs: 419 tools: pamac,paru pm: flatpak pkgs: 8
Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.28
System install date: 2023-06-21
Last full system update: 2023-08-10
