Hi guys, for a few days now, after turning it off, it freezes here and I have to force it to turn off.
Any suggestions?
Thank you.
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=671de9f9-8ee6-4c92-a404-549bf7935a22 rw rootflags=subvol=@
quiet loglevel=3 nvidia_drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5003 date: 10/07/2023
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2447 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3168
3: 2200 4: 2200 5: 3800 6: 2200 7: 2200 8: 3595 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 121373
Device-1: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: ZOTAC driver: nvidia
v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 0a:00.0
chip-ID: 10de:2782 class-ID: 0300
Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3
chip-ID: 0c45:8006 class-ID: 0301
Device-3: Sunplus Innovation Aukey-PC-LM1E Camera
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 5-1:2 chip-ID: 1bcf:0215 class-ID: 0102
d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-1 pos: top-right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
memory: 11.71 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Ti driver: nvidia v: 550.67 device-ID: 10de:2782
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.2 (LLVM 17.0.6)
Device-1: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:22bc class-ID: 0403
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
Local Storage: total: 10.01 TiB used: 48.79 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Smart Modular Tech.
model: SHPP41-1000GM size: 931.51 GiB block-size: physical: 512 B
fw-rev: 51060A20 temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.2 temp: 27.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40EFRX-68WT0N0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: GPT
used: 48.79 GiB (5.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
System Temperatures: cpu: 41.5 C mobo: N/A
Memory: total: 32 GiB available: 31.25 GiB used: 3.55 GiB (11.3%)
Processes: 341 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1632 libs: 469
tools: octopi,paru,yay pm: flatpak pkgs: 0 Compilers: clang: 17.0.6
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-01-21
Last full system update: 2024-03-31
Hi @Pasqui , Does the issue start occurring after a recent system update? If it did, try rolling back to a previous snapshot to see if the problem resolves.
→ if it did please check and share what packages causing the problem
filo
31 March 2024 08:13
3
To gather more information, you could remove the quiet boot parameter and also check the journal (-b -1 for the previous boot).
You could also try if you have the same problem in an x11 session at login, as opposed to wayland.
If so, you could also try installing and booting onto a different kernel, e.g. linux-lts (install also linux-lts-headers).
Another thing you could try is to boot to a TTY and then shutdown. In this case the problem could be SDDM or nvidia.
I suspect it’s the bluetooth service (bluez)…
Activation request for ‘org.bluez’ failed.
journalctl -rb -1 here
edit:
journalctl -b 1 here
NaN
31 March 2024 17:09
5
Hey can you remove packagekit from your system and test if it affects anything? This won’t be the first time I have seen this package causing issues for it’s users.
My computer repeatedly was slowing down, stuttering and I did not understand why. Then I used htop to see that this program called packagekit is using all of my cpu and ram available to the point where it is crashing.
[PXL_20240131_134317557]
I removed packagekit and this fixed all issues for me. I guess I just wanted to let you know that this is an issue.
here is my garuda-inxi if required:
Kernel: 6.7.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc avai…
I have a very similar problem. I hope it’s helpful for me to also post details rather than just saying “I am experiencing the same thing.” I will try to troubleshoot tomorrow as it’s getting a bit late here and will post my findings.
root=UUID=1261b908-7b87-4e2a-9db0-289edd5174ef rw rootflags=subvol=@
loglevel=3 ibt=off
Mobo: ASUSTeK model: PRIME B550M-A (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 3404 date: 10/07/2023
Speed (MHz): avg: 2698 high: 4199 min/max: 2200/5361 boost: disabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2200 2: 4199
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 4199 10: 2200 11: 4181
12: 2200 13: 2200 14: 4199 15: 2200 16: 2200 bogomips: 134406
Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-1, DP-3, HDMI-A-1, Writeback-1 bus-ID: 0d:00.0
chip-ID: 1002:747e class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 res: 2560x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 17.0.6 DRM 3.57 6.8.2-zen2-1-zen) device-ID: 1002:747e
API: Vulkan v: 1.3.279 layers: 15 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 24.0.3-arch1.2
device-ID: 1002:747e surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab30
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 0a:00.0 chip-ID: 10ec:8168
IF: enp10s0 state: down mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 8087:0029
Local Storage: total: 2.51 TiB used: 766.66 GiB (29.9%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 44.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
lanes: 4 tech: SSD serial: <filter> fw-rev: S8J41100 temp: 44.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: LITE-ON model: LCH-256V2S
tech: SSD serial: <filter> fw-rev: 901 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ04UBF100
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 5438 scheme: MBR
used: 446.26 GiB (47.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:3
used: 29.7 MiB (30.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
ID-4: /var/log raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
System Temperatures: cpu: 37.5 C mobo: 36.0 C gpu: amdgpu temp: 49.0 C
mem: 54.0 C
Fan Speeds (rpm): fan-1: 426 fan-2: 828 fan-3: 411 fan-7: 4115 gpu: amdgpu
fan: 0
Memory: total: 32 GiB available: 31.25 GiB used: 4.75 GiB (15.2%)
Processes: 409 Power: uptime: 47m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: 2077 pm: pacman pkgs: 2058 libs: 598 tools: octopi,paru
pm: flatpak pkgs: 19 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-02
My PC is not slowed down and no process uses excess RAM and CPU.
It only remains blocked after the shutdown phase (oddly enough when Bluetooth is active).
filo
3 April 2024 13:58
9
Possibly related (it looks like a bluetooth issue with the latest kernel actually):
https://bbs.archlinux.org/viewtopic.php?pid=2161144
And relevant links therein.
SGS
3 April 2024 17:04
10
The “funny” thing is that it also changes the DHCP setting in the BIOS, so WOL no longer works. Only
sudo poweroff
works for me.
It is also strange that on a multiboot computer it only happens with KDE and Hyprland and not with i3wm.
Thanks for the link.
Seems to be fixed in 6.8.3… I’ll wait
For now, thank you all for your availability, you are fantastic!
system
Closed
6 April 2024 18:25
12
