System Still Freezes on Raptor (Monitors Won't Wake)
Hi all,
I'm still having this issue where sometimes the system becomes unresponsive when the monitors go into power-saving mode. I updated my BIOS to the latest version, and I reinstalled the operating system after Raptor came out.
I connect the Garuda (KDE) laptop to two monitors with Thunderbird, but after it freezes like this, I can't get the system to respond even after unplugging it from the monitors (the laptop's keyboard or mousepad won't do anything; I have to hold down the power button to shut down).
Does anyone have any advice? Is this a known issue? I can't find any evidence of others having this issue by searching this forum, but I'm running this on a 2022 Lenovo ThinkPad E15. And I'm using the open-source drivers. So it seems odd to have this issue given that I'm using reasonably new hardware with the latest BIOS and with the latest version of Garuda.
If I can't figure this out, I think I'll see if Garuda Cinnamon works better before looking into other distros.
Thank you!
Kernel: 6.2.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c7def35e-1e94-4346-a7db-7774a2ce2ce7 rw rootflags=subvol=@
quiet rd.luks.uuid=4402a1e8-5cd1-4f9e-b0a2-fda17e8747e1 quiet splash
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20TD003KUS v: ThinkPad E15 Gen 2
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 20TD003KUS v: SDK0J40697 WIN
serial: UEFI: LENOVO v: R1EET52W(1.52 )
date: 07/06/2022
ID-1: BAT0 charge: 42.5 Wh (99.1%) condition: 42.9/45.0 Wh (95.4%)
volts: 12.3 min: 11.1 model: Sunwoda 5B10X025 type: Li-poly serial:
status: not charging cycles: 32
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1865 high: 2400 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 2400 3: 964
4: 2400 5: 1033 6: 2400 7: 930 8: 2400 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-5,DP-7 empty: DP-1, DP-2, DP-3, DP-4, DP-6, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Luxvisions Innotech Integrated Camera type: USB driver: uvcvideo
bus-ID: 4-8:2 chip-ID: 30c9:003a class-ID: fe01 serial:
s-diag: 1055mm (41.54")
Monitor-1: not-matched mapped: DP-1-1 pos: left res: 1920x1080 hz: 60
dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: not-matched mapped: DP-1-3 pos: primary,right res: 1920x1080
hz: 60 dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl bus-ID: 3-2.1.1.2:9
chip-ID: 17ef:3083 class-ID: 0300 chip-ID: 8086:a0c8 serial:
class-ID: 0401
Device-2: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio type: USB
Sound API: ALSA v: k6.2.2-zen2-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
IF: wlp0s20f3 state: up mac:
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac:
Device-3: Lenovo ThinkPad TBT 3 Dock type: USB driver: r8152
bus-ID: 6-2.1.2:4 chip-ID: 17ef:3082 class-ID: 0000 serial:
IF: enp10s0u2u1u2 state: up speed: 1000 Mbps duplex: full mac:
bus-ID: 4-10:3 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address:
Local Storage: total: 476.95 GiB used: 11.43 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
model: MZVLQ256HAJD-00000 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: FXV7101Q temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZALQ256HAJD-000L1 size: 238.47 GiB block-size: physical: 512 B
rev: EL1QFXV7 temp: 24.9 C scheme: GPT
used: 11.43 GiB (4.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-4402a1e8-5cd1-4f9e-b0a2-fda17e8747e1
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 1900 fan-2: 1900
Processes: 284 Uptime: 58m wakeups: 3 Memory: 15.33 GiB
used: 7.15 GiB (46.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1323
libs: 358 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-06
Last full system update: 2023-03-10
I’d try this:
https://wiki.archlinux.org/title/Laptop/Lenovo#ThinkPad_E15_Gen_2
Maybe unrelated but worths a shot.
Also a kernel switch would be worth trying.
Edit: My bad, that suggestion as-is is not applicable with dracut (you need to check if there is an equivalent module).
Oh thank you so much! I totally missed that Wiki page.
