Hey there,
I'm really stumped with a problem that I'm experiencing for a few days now. I have a lot of problems, but I think they are all related. To keep it short, here is a list:
- Librewolf regularly slows down greatly. Tabs take ages to load, and it starts using more cpu cycles than I would expect. Even on browser-internal tabs
- FreeTube download speeds go from 30mbps down to a few kbps until I restart the application. Doing that also isn't as easy as it takes quite a while to even build the application window and stuff.
- Pacman is awfully slow (Yes I tried refreshing the mirrors). Pacman takes a few minutes to install the tiniest packages and the download speeds are also horrible. The pacman hooks like the foreign package notification are very slow. It does not spit out a huge block of text like it used to (because it was going so quick) but instead I can actually count the lines it prints out.
- Evolution (my mail application) takes very long to download mails and stuff. Sending is equally as worse, even freezing the application.
- My backup HDD is once again blocked by a weird kernel file sync daemon making it read-only until I reboot.
- Writing this, systemd-journald crashed, and failed to start like five times (log)
Any idea what's going on? I'm gonna try the LTS kernel, and downgrading zen, but there is not much more that I can do without some help.
Thanks!
Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 12.2.1
parameters: root=PARTUUID=fec66b8f-995b-8043-94b0-fcc9535362ba
rw add_efi_memmap [email protected]
[email protected]\boot\amd-ucode.img
rd.udev.log_priority=3
vt.global_cursor_default=0
sysrq_always_enabled=1 iommu=soft
initrd=\@\boot\initramfs-linux-zen.img
Desktop: Hyprland info: waybar vt: 1
dm: greetd Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte
product: AX370-Gaming 3 v: N/A
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x
UEFI: American Megatrends v: F50a
date: 11/27/2019
Info: model: AMD Ryzen 5 2600X bits: 64
type: MT MCP arch: Zen+ gen: 2 level: v3
note: check built: 2018-21 process: GF 12nm
family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12
smt: enabled cache: L1: 576 KiB
desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2427 high: 3600
min/max: 2200/3600 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil
cores: 1: 2163 2: 2200 3: 1938 4: 2200 5: 2200
6: 2200 7: 2012 8: 2103 9: 3200 10: 3110
11: 2200 12: 3600 bogomips: 86226
Flags: avx avx2 ht lm nx pae sse sse2 sse3
sse4_1 sse4_2 sse4a ssse3 svm
Device-1: AMD Baffin [Radeon RX 550 640SP /
560/560X] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1
bus-ID: 08:00.0 chip-ID: 1002:67ff
class-ID: 0300 temp: 41.0 C
Device-2: Logitech Webcam C270 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 2-3.4:6
chip-ID: 046d:0825 class-ID: 0102
Display: wayland server: Xwayland v: 23.1.1
compositor: Hyprland driver: X: loaded: amdgpu
unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: 1
Monitor-1: DVI-D-1
model: Apple Cinema HD Display serial: <filter>
built: 2003 res: 1920x1200 dpi: 99 gamma: 1.2
size: 495x310mm (19.49x12.2")
diag: 584mm (23") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
Monitor-2: HDMI-A-1 model: Samsung SyncMaster
serial: <filter> built: 2007 res: 1680x1050
dpi: 90 gamma: 1.2
size: 474x296mm (18.66x11.65")
diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
API: EGL/GBM Message: No known Wayland
EGL/GBM data sources.
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX
550 640SP / 560/560X] vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 1-1:2
chip-ID: 0d8c:9700 pcie: class-ID: 0300 gen: 3
serial: <filter> speed: 8 GT/s lanes: 8
bus-ID: 08:00.1 chip-ID: 1002:aae0
Device-2: AMD Family 17h HD Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0a:00.3 chip-ID: 1022:1457
Device-3: C-Media USB Microphone type: USB
Device-4: Logitech Webcam C270 type: USB
API: ALSA v: k6.2.10-zen1-1-zen
status: kernel-api tools: alsamixer,amixer
Server-1: sndiod v: N/A status: off
tools: aucat,midicat,sndioctl
Server-2: PipeWire v: 0.3.68 status: active
with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin
Device-1: Realtek RTL8111/8168/8411 PCI Express
Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 03:00.0 chip-ID: 10ec:8168
IF: eno1 state: up speed: 1000 Mbps
duplex: full mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0
type: USB driver: btusb v: 0.8 bus-ID: 2-4.2:7
chip-ID: 0a5c:21e8 class-ID: fe01
Report: bt-adapter ID: hci0 rfk-id: 0
state: up address: <filter>
Local Storage: total: 2.96 TiB
used: 1.93 TiB (65.2%)
SMART Message: Unable to run smartctl. Root
privileges required.
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung
model: SSD 860 EVO 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung
model: SSD 860 EVO 250GB size: 232.89 GiB
rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32
vendor: Western Digital model: WD20EFRX-68EUZN0
size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 0A82
ID-4: /dev/sdd maj-min: 8:48 type: USB
vendor: Intenso model: Rainbow Line
size: 7.5 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter>
rev: 8.07 scheme: MBR
SMART Message: Unknown USB bridge. Flash
drive/Unsupported enclosure?
ID-1: / raw-size: 195.03 GiB
size: 195.03 GiB (100.00%)
used: 60.73 GiB (31.1%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 736.18 GiB
size: 736.18 GiB (100.00%)
used: 183.19 GiB (24.9%) fs: btrfs
dev: /dev/sda3 maj-min: 8:3
ID-3: /var/log raw-size: 195.03 GiB
ID-4: /var/tmp raw-size: 195.03 GiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 31.3 GiB
used: 3.9 MiB (0.0%) priority: 100
System Temperatures: cpu: 39.2 C mobo: N/A
gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1491
Processes: 373 Uptime: 5h 42m wakeups: 1
Memory: 31.3 GiB used: 5.86 GiB (18.7%)
Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1
clang: 15.0.7 Packages: pm: nix-default pkgs: 0
pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0
pm: pacman pkgs: 1712 libs: 491 tools: yay
Shell: Zsh v: 5.9 running-in: alacritty
inxi: 3.3.26
System install date: 2023-01-08
Last full system update: 2023-04-11
Is partially upgraded: Yes
Why does it say that I'm partially upgraded? I only installed a package, nothing more...
