I will start off with this…
╭─fenris@fenris in ~ as 🧙 took 0s
╰─λ sudo garuda-inxi
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4bf0d9ca-8f27-4679-8b43-3a354dfc3679 rw rootflags=subvol=@
quiet rd.luks.uuid=bea4912e-5a23-42eb-9d27-82a419d47ffd
rd.luks.uuid=b03a83d6-92ca-4ba6-9859-c3ad1f02206e
resume=/dev/mapper/luks-b03a83d6-92ca-4ba6-9859-c3ad1f02206e loglevel=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
Type: Mini-pc Mobo: AZW model: EQ serial: N/A
uuid: 68ce8b00-6aeb-11ef-8ec5-a4a2b6b92601 UEFI: American Megatrends LLC.
v: FP7T107 date: 07/22/2024
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
Speed (MHz): avg: 1199 min/max: 400/4935 boost: enabled
base/boost: 3300/4925 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1199 2: 1199 3: 1199 4: 1199
5: 1199 6: 1199 7: 1199 8: 1199 9: 1199 10: 1199 11: 1199 12: 1199
13: 1199 14: 1199 15: 1199 16: 1199 bogomips: 105405
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
active: HDMI-A-1,HDMI-A-2 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
DP-7, Writeback-1 bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 55.0 C
Device-2: Creative Vimicro USB 2.0 PC Camera(MARS)
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-2.1:3 chip-ID: 041e:40a0 class-ID: 0102
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 3280x1080 s-dpi: 96 s-size: 867x285mm (34.13x11.22")
s-diag: 913mm (35.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: left model: HKC TV
serial: <filter> built: 2015 res: 1360x768 hz: 60 dpi: 45 gamma: 1.2
size: 760x450mm (29.92x17.72") diag: 806mm (31.7") ratio: 16:9, 15:9
modes: max: 1360x768 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary,right model: HP LA2206
serial: <filter> built: 2011 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
LLVM 18.1.8 DRM 3.59 6.11.5-zen1-1-zen) device-ID: 1002:1681
memory: 3.91 GiB unified: no
API: Vulkan v: 1.3.295 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 24.2.5-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.5-arch1.1 (LLVM
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: JMTek LLC. LCS USB Audio
lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0c76:2018 class-ID: 0300
Device-5: Creative Vimicro USB 2.0 PC Camera(MARS)
Device-6: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 7-1:2 chip-ID: 0d8c:0102 class-ID: 0300
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: n/a (root, process) with:
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 8087:0029
Local Storage: total: 3.64 TiB used: 210.28 GiB (5.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 51.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 45.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 0202 scheme: MBR
ID-1: / raw-size: 909.97 GiB size: 909.97 GiB (100.00%)
used: 210.28 GiB (23.1%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
maj-min: 254:1 mapped: luks-bea4912e-5a23-42eb-9d27-82a419d47ffd
used: 728 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 909.97 GiB size: 909.97 GiB (100.00%)
ID-4: /var/log raw-size: 909.97 GiB size: 909.97 GiB (100.00%)
ID-5: /var/tmp raw-size: 909.97 GiB size: 909.97 GiB (100.00%)
ID-1: swap-1 type: partition size: 21.25 GiB used: 0 KiB (0.0%)
mapped: luks-b03a83d6-92ca-4ba6-9859-c3ad1f02206e
ID-2: swap-2 type: zram size: 19.31 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: 44.8 C gpu: amdgpu temp: 55.0 C
Memory: total: 20 GiB available: 19.31 GiB used: 7.58 GiB (39.2%)
Processes: 523 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 7.71 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1666 libs: 446 tools: pamac,paru,yay Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.36
System install date: 2024-10-21
Last full system update: 2024-10-24
Failed units: vmware.service
╭─fenris@fenris in ~ as 🧙 took 4s
╰─λ
So my situation is very simple… I do garuda-update --aur
, it goes through compiling 63,000 processes of Ungoggled Chromium, then one third of the way through the update…my system just turns it self off. No warning, no notice that it’s coming, just poof off my system goes.
It sounds like it might be time to put Ungoogled Chromium in Chaotic-aur
